emergency question for wiring head deck
Postby Low_Aa63 » Mon Jan 23, 2006 3:39 pm
if you are reading this in like the next 2 mins please advise.....
i am wiring a headunit into the factory toyota radio loom of an 1981 toyota soarer....
I have found this http://www.installdoctor.com/Harnesses/ ... Wiring.pdf file to be the most accurate i can find but the colouring of the wires is different...
question... should i continue with the wireing ignoring the colour specs on this pdf???
HELP!!
The list so far
Te71, Ae82, Ke70x2, Mx73x2, Ga61, Gx61, Ra63, Aa63, Ae70, Ae85, Ke25, Ke30, Ke36, Gz10x2, Hb11, Ta40, Ma45......
geishaboy wrote:I want a number plate with "geisha" on it
But I should probably get a car first
Low_Aa63
Postby DeeCee » Mon Jan 23, 2006 3:43 pm
no
GT Four Adovansu
DeeCee
Postby cespenar » Mon Jan 23, 2006 3:44 pm
got a multimeter? or try a 12v bulb between what it says as ground and battery..if its not what it says should blow a fuse...but could be dangerous
cespenar
Postby Low_Aa63 » Mon Jan 23, 2006 5:22 pm
ok so what i found out was that the rear speakers were as indicated on the smaller connection into the factory head-unit but the larger block i beleive to be reversed.. as the 12 main in the smaller block was indeed a 12 v main but the 12v ign wasnt......
if ive given the head unit constant power do i have to install i switch inline on the amp rem??
Ben
The list so far
Low_Aa63
