Custom Box spec's
Custom Box spec's
Postby Infinite » Sun Feb 05, 2006 7:11 pm
Hi,
I have 2x 525watt Jensen sub's and need to make a custom box for them in my car but am not sure what spec to make the box at? anyone able to point me in the right direction?
Lots
Infinite
Postby AE82 FXGT » Sun Feb 05, 2006 7:36 pm
yep
http://forums.nzicemag.co.nz
they'll point you in the right direction
AE82 FXGT
Postby Infinite » Sun Feb 05, 2006 7:49 pm
hehe yeah was gona look thru there guys who write that mag come into work every so often :) pick up a few bits of crap todo glassing
Lots
Infinite
Postby DeeCee » Sun Feb 05, 2006 9:22 pm
what are the model numbers of the jensen's?
GT Four Adovansu
DeeCee
Postby Infinite » Sun Feb 05, 2006 9:38 pm
just XS12
Lots
Infinite
Postby DeeCee » Sun Feb 05, 2006 10:02 pm
i would look at the manual for the subwoofer here:
http://www.audiovox.com/manuals/owners/ ... lfinal.pdf
take the jensen advice otherwise download WinISD and have a play.. unfortunately i don't have time to enter in T/S specs and play with boxes for you soz..
GT Four Adovansu
DeeCee
Postby Infinite » Mon Feb 06, 2006 12:51 pm
so u go n make the box but then the support for the back rear window hits it >_< fking pos! so u modify the box and have to do some wacked #$#@ to make it fit then u just rip it all back out and give up...........
Next weekend im going to remove spare wheel mount the amps in the hole, Then make a false floor shove some led's under there window to see amp ect ect then move the subs out from the boot more so i can a bigger box..... after all im a member of AA so dont need that tyre :P
Lots
Infinite
Postby Jazza » Mon Feb 06, 2006 2:00 pm
Exactly what i did with my curren, if youd like and you live in Auckland feel free to PM me or gimme a call and ill show ya how i worked my sounds. I cant access my spare tire either :P AA rocks :P
1996 Curren - On Tardme
Jazza
Postby XERO » Mon Feb 06, 2006 5:42 pm
Next weekend im going to remove spare wheel mount the amps in the hole, Then make a false floor shove some led's under there window to see amp ect ect then move the subs out from the boot more so i can a bigger box..... after all im a member of AA so dont need that tyre :P[/quote]
Dont you need it for your WOF???? :?
Altezza RS200 Z Edition
For performance parts :: www.drivenperformance.co.nz
XERO
Postby Alex B » Mon Feb 06, 2006 5:52 pm
nope.
Postby gt-trainer » Tue Feb 07, 2006 5:21 pm
So then it goes like this.......AA man arrives and finds young man with flat tyre :( , mutters to himself that should know how to change his own bloody tyre : 8O Having established the problem and opening the boot only to dicover young man has filled boot full of car audio and removed spare tyre asks how he is going to help without the spare :wink:
Quote......"after all im a member of AA so dont need that tyre "
:D :D :D :D :D :D :D What do you think they gonna do call a tow truck for you :?:
gt-trainer
Postby Alex B » Tue Feb 07, 2006 5:32 pm
Normaly that would be fine, unless your say on a very un used track in central otago with no cell phone reception....
Postby Mr.Phreak » Tue Feb 07, 2006 6:12 pm
May want to read http://www.aa.co.nz/Section?Action=View&Section_id=122&Story_id=1234
Taking note of the exclusions, specifically When the vehicle is immobilised by the failure to carry a serviceable spare wheel and wheel changing equipment suitable to the vehicle
Mr.Phreak
Postby Infinite » Tue Feb 07, 2006 6:36 pm
awww :( spoil sport!!!
Lots
Infinite
Postby Jazza » Tue Feb 07, 2006 8:38 pm
So ill drive it on the flatty and wreck the stock alloys so i NEED new rims... :lol: 8)
Jazza
