Uniden Alarm Remote - Help Reprogramming
Postby Glycerine » Wed Feb 15, 2006 9:31 pm
so my misses has a uniden alarm installed in her car...
not sure what modle as it was installed before we bought the car,
recently she managed to soak one of the remotes,
so we opened it up and let it dry...
how ever i think the water caused it to loose its programming,
as it still blinks when buttons are pushed but it wont opperate the alarm.
doz anyone know what has to be done to reprogram it??
Thanks
Glycerine
Postby Alex B » Wed Feb 15, 2006 9:32 pm
Depends on the alarm, i think you just turn the ignition 3 times in 10 seconds to set it up on the cheepest one.
Postby Glycerine » Wed Feb 15, 2006 9:35 pm
i know its better than the basic modle...
ill give it a go anyway..
do you need to push any buttons after doing that??
tried that didnt work
Glycerine
Postby Alex B » Wed Feb 15, 2006 9:40 pm
yes, you need to push button one i think. IT will beep at you when your in teh set up mode.
Postby Glycerine » Wed Feb 15, 2006 9:44 pm
didnt work :(
Glycerine
Postby t0ms » Thu Feb 16, 2006 5:42 pm
depends what model...
also do you know if the remote is actually outputting ???? the LED may be going but the remote may not. go to your local alarm/auto electrician shop and get them to check it out
t0ms
Postby Glycerine » Thu Feb 16, 2006 6:28 pm
got it working, thanks people
Glycerine
