Need Answers
Need Answers
Postby Flange » Tue Mar 07, 2006 6:52 pm
Just need to know how to wire up for 2ohm
Got 600wrms @2ohm 2 channel amp with DVC 2ohm stable sub.
How do i wire it up??
Flange
Postby Alex B » Tue Mar 07, 2006 6:58 pm
I think youl find its not stable, it will probly be 2 ohm stereo stable, but not bridged. Most are that way.
Postby Flange » Tue Mar 07, 2006 7:03 pm
pyro_sniper2002 wrote:I think youl find its not stable, it will probly be 2 ohm stereo stable, but not bridged. Most are that way.
whats that mean? any way to get around it?
Flange
Postby [A NINJA] » Tue Mar 07, 2006 8:38 pm
what flavour amp do you have? www.nzicemag.co.nz for teh win
www.tusken-raiders.tk
NINJA!!!!!!!!
[A NINJA]
Postby Flange » Thu Mar 09, 2006 6:35 pm
[A NINJA] wrote:what flavour amp do you have? www.nzicemag.co.nz for teh win
a p6001 rockford amp and s12l5 kicker sub?
Flange
Postby Alex B » Thu Mar 09, 2006 7:39 pm
isnt a p6001 a monoblock??
Postby Flange » Fri Mar 10, 2006 9:35 pm
pyro_sniper2002 wrote:isnt a p6001 a monoblock??
think so? I'm complete audio n00b so whats wrong with that?
I just want to know how to wire it up thanks if i can. Cheers for your help guys :wink:
Flange
Postby Zyros » Fri Mar 10, 2006 10:16 pm
If you have just that amp for the sub, just plug and go?
Monoblock means just a 2/1 chanel amp. Monoblocks are mainly just used to power 1 sub.
Zyros
Postby Flange » Sat Mar 11, 2006 10:33 am
Zyros wrote:If you have just that amp for the sub, just plug and go?
Oh yep, the sub has 4 input things. How do i wire that up or do i just run one voice coil?
Cheers guys i need help :oops:
Flange
Postby Zyros » Sat Mar 11, 2006 11:03 am
You run RCA cables from the headunit which plug into those inputs (if you have it, make sure you plug it into the sub-preout)
Then run those RCA's from the headunit into the amp.
You need 2 inputs to run one speaker, hence why yours is a 2 channel amp. It has 4 inputs, but you can run two speakers off it cause each speaker uses two of those inputs.
Zyros
Postby Mr.Phreak » Sat Mar 11, 2006 1:43 pm
My guess is he's not talking about the RCA inputs, he's meaning the speaker terminals on the sub
Is it the Dual 2 Ohm, or Dual 4 Ohm version of the sub??
Mr.Phreak
Postby Flange » Wed Mar 15, 2006 9:35 pm
Mr.Phreak wrote:My guess is he's not talking about the RCA inputs, he's meaning the speaker terminals on the sub
I am fairly sure it is the Dual 2 Ohm version
Zyros: Thanks :roll:
Flange
Postby Alex B » Wed Mar 15, 2006 9:58 pm
Zyros wrote:You need 2 inputs to run one speaker, hence why yours is a 2 channel amp. It has 4 inputs, but you can run two speakers off it cause each speaker uses two of those inputs.
WTF are you an about??
1 speaker requires one input. If a 2ch amp has 4 rca's its usuasy for a pass throu. and a p6001 IS a monoblock with pass throu. Go to forums.nzicemag.co.nz, to many know alls round here.
Postby Mr.Phreak » Wed Mar 15, 2006 11:14 pm
If it is the Dual 2 version, then it's not really well matched to the amp you have.....
It can run with the coils in parallel for a 1 ohm load which will probably give the amp a heart attack, or in series for a 4 ohm load which will work, but isn't really making the most of the amp which is designed to make its best power with a 2 ohm load.
Have a read through http://www.bcae1.com/srsparll.htm and the rest of the bcae site if you have time.
Mr.Phreak
Postby Flange » Sat Mar 18, 2006 12:35 pm
Mr.Phreak wrote:If it is the Dual 2 version, then it's not really well matched to the amp you have.....
Finally some proper answers haha thanks man i will have a read of that site (Reading now). Which sub would go well with the amp?
Flange
Postby Mr.Phreak » Sat Mar 18, 2006 10:44 pm
Either a 2 Ohm Single Voice Coil Sub, or a DVC Sub with 4 ohm coils which can be paralleled so that the amp sees a 2 ohm load.
The sub you have comes in both Dual 2 ohm, and Dual 4 ohm, so it may pay to check which it is before replacing it....also if it turns out that it is the Dual 2 ohm version and you bought the sub and amp as a pair, I'd consider whinging to whoever sold them to you
Mr.Phreak
Postby Flange » Wed Mar 29, 2006 11:26 pm
Mr.Phreak wrote:Either a 2 Ohm Single Voice Coil Sub, or a DVC Sub with 4 ohm coils which can be paralleled so that the amp sees a 2 ohm load.
mate just found out its a dual 4 ohm :) so run it in parallel?
Flange
Postby Mr.Phreak » Wed Mar 29, 2006 11:36 pm
Yup
Mr.Phreak
Postby Zyros » Wed Mar 29, 2006 11:44 pm
RCA cables have two plugs, so plug in to two inputs? Maybe ive just worded it wrong.
Zyros
Postby Alex B » Thu Mar 30, 2006 12:00 am
yes but a sub is only a mono channel. You dont need duel inputs.
