AE111 Levin Speaker sizes
Postby BZR4AGE » Tue Jun 20, 2006 12:42 pm
Hi there guys. was wondering if anyone can confirm for me.
The rear speaker size are 6.5 inch or 6inch
and the front are 6 inch or 6.5.
Is for a AE111 Levin, Cheers
BZR4AGE
Postby john_l » Mon Jun 26, 2006 12:32 pm
Yup - although the actual front door holes have about a 7 or 8" opening, so you'll have to make some mdf spacers up for 6-6.5" speakers..
And if you want 6x9s in the back (don't) then you'll have to use spacers or drill through the steel stuff.. But 6.5" speakers will fit fine in both places..
Just make sure the mounting depth of the front door speakers don't hit against the window... or block it, so install them with the windows down..
It's also a pain to get the door panels off for the first time.. Once you know how it's easy.
But good luck with your install.
john_l
