Headunit power help
Headunit power help
Postby Zyros » Fri Jun 23, 2006 7:09 pm
Hey, i installed a headunit today... and the headunit is always on even with the key out.. just remains on, i think its because we have the yellow (constant) and red (12V) bridged due to the constant wire in the loom not working, what else could we hook the constant wire (yellow) up to.. thanks.
Zyros
Postby Punter » Fri Jun 23, 2006 7:46 pm
You could just run a new power feed from the batterey, the lugs and fuse' wouldn't cost more the $10.
Punter
Postby flat_0ut » Fri Jun 23, 2006 7:55 pm
you could run a new wire for acc
flat_0ut
Postby cespenar » Fri Jun 23, 2006 8:16 pm
Red should be wired to ACC or ON from the ignition switch, yellow should always have power no matter which position ignition is on... Sounds like you have the yellow alright, but the red is wrong
cespenar
Postby Zyros » Fri Jun 23, 2006 10:49 pm
cespenar wrote:Red should be wired to ACC or ON from the ignition switch, yellow should always have power no matter which position ignition is on... Sounds like you have the yellow alright, but the red is wrong
Whats ACC? Or how do we wire it to this.. 'on' from the ignition?
Zyros
Postby no_8wire » Fri Jun 23, 2006 11:01 pm
wired the ACC from the cig lighter...
no_8wire
Postby Alex B » Fri Jun 23, 2006 11:02 pm
:roll: why do a half ass job? installdoctor.com
Postby flat_0ut » Fri Jun 23, 2006 11:50 pm
one wire that goes in is acc which gives it all its power when you turn the key to acc/on. the power wire just holds the settings in it.
flat_0ut
