need help : toyota corolla ceres 93
Postby LEV_101 » Sun Nov 19, 2006 9:58 am
hi there guys,
if someone knows the answer can you tell me what size speakers are on the front
and also, how to take the door panels off to access to the speaker.
many thanks
tommy
LEV_101
Postby KinLoud » Tue Dec 12, 2006 10:28 pm
I have a marino which is very similar to the Ceres.
Just put new speakers in the front and rear.
Both front and rear speakers have plastic adapters that hold the speaker and bolt onto the metalwork of the car.
Front - diameter of hole in plastic adapter 145mm. Diameter for screw holes 160mm.
I have fitted 6.5inch Jaycar Kevlar speakers front and rear. These have pretty big magnets so I had to fiddle around a bit to make them fit well.
I had to file out a bit of the front plastic adapter so the magnet would fit through.
On the rear I had to bend a little bit of the metalwork so the magnets would fit also.
Door trim off.
From memory (mostly correct I think):
Pop off the plastic screw covers at the hinge end of the door trim - remove screws.
Push in the centre of the plastic clips at the latch end of the trim, then carefully pry out with screwdriver.
Remove screw that holds the plastic door cup/handle (where you put your fingers to close the door), remove cup/handle.
Lever out bottom of door trim with a screwdriver... put screwdriver between door card and metal at the bottom of the door. Don't try to remove door card yet!
Use a small screwdriver on the door latch lever (the bit you pull to open door from the inside). Put the screwdriver between the plastic surround and the pivot point of the door latch lever and pop the surround off. Do this above and below the pivot point. I THINK THIS BIT IS CORRECT?
Wind down the window.
Lift the door card up and away from the door.
Unplug the window winder switches etc.
Good luck
Ken
Ham
021 48 863
door latch lever pivot point.
