Power antenna help!!
Postby Capin-Neemo » Tue Dec 19, 2006 4:04 pm
I have a Celica 91 GTR 4WS
cant get my power antenna to work and for one have no idea wich wire is the power antenna for the sterio im so lost please help!
Oh and aparently there are two antennas in celicas from what i can see one goes to the back hatch and the other is the power one this is even more confusing!!
:oops:
Neemo Out
Capin-Neemo
Postby Mr.Phreak » Tue Dec 19, 2006 5:56 pm
Mr.Phreak
Thanx!
Postby Capin-Neemo » Wed Dec 20, 2006 9:10 am
Thanx big help good work!
I aloso found out for any one who is interested that the power antenna is only and am one and runs to the secondary cord behind the stero. (Smaller areial plug). IOt is for the stock jap head units.
So if you attach the sterio arial wire to the red and black striped wire in the power headder for your head unit, you get one power anttena if it work and two power to the FM amp modual witch is under the boot lid behind the plastic panel. So if your power anttena dosent work dont fret unless you like to listen to clasical just pull it out and install a standar manual one as long as you power the FM modual youll be able to listen to the ROCK! sweet as.
Neemo Out
Capin-Neemo
