Have noticed that the door lock barrel on the drivers side has been pushed in. No real damage at all to the handle surround or anything...
BUT now the alarm (won't say which other than it is a Dynatron with a couple of uprated features)... anyway, now it operates oddly... As in, the LED does not flash at all, the siren does not always go off if I arm it, sit inside and then open the door and further more the drivers door does not always lock which is something I noticed a little while ago when I checked after arming the car and the drivers door wasn't locked (should of seen my face
Inside the car and under the bonnet all is sweet - wiring to siren all there, no damage (they don't appear to have got in as nothing at all was missing)...
I have had issues from day one with this alarm, the biggest problem was when it malfuntioned (has been admitted to by the manufacturer) causing the starter motor to remain engaged the entire time which caused it to have one hell of a meltdown one day in a heck of a lot of smoke and luckily no fire! A tow and fix later for about $500 (which I have yet to be compensated for but understand is on its way) and i was back on the road (after getting the bumper fixed due to the tow truck driver hooking it instead of the tow hook - go figure!).
So, firstly how the hell do get a new lock/handle or it fixed? Am assuming this is toyotas domain?
Secondly, what can one do to make the car anymore secure or is it just 'one of those things'?
If I could only get my hands and baseball bat on those &^%(^%$ little so n so's...
All help and advice appreciated. Apologies for the essay, can beat up the would-be theifs so am venting here...
