Impedance of pc sound output
Postby UTERUS » Fri Jun 08, 2007 9:45 pm
So i want to have a play with a sub that will be powered through a 12v car amp and i want to know if it will be happy with a signal from the computer, computers speakers are around 8 ohms arent they?
It is a myth that emos are contagious, and you may be infected. However, it is still widely accepted to wash your hands after physical contact
UTERUS
Postby pidge » Fri Jun 08, 2007 9:57 pm
PCs / Soundcards (now adays) don't have "speaker out"*, just line out, which is what amps will be expecting. It just may not be 2V or 4V peak to peak, it wil probably be the "normal" 1V p-p.
* apart from a few older soundblaster and clones (ISA slot) and a few odd-ball motherboards (one with a vaccum tube amp!). Exceptional exceptions.
pidge
Postby UTERUS » Fri Jun 08, 2007 10:01 pm
Just what i wanted to know, cheers!
UTERUS
