Engine Interferance
Engine Interferance
Postby RevolutionStarlet89 » Thu Jun 14, 2007 3:59 pm
Ok so i just wired my back speakers to my amp, and i get a very low level of what sounds like alternator interfreance, i brought a 5 amp noise level filter but now i cant get some stations and some times the noise is worse!:S any 1 got any ideas on whats going on?? When i play a cd it works fine and there is no interference, it just seems to be with the radio.
SKoty
Current Current Ride: 1992 Toyota Trueno Gt Apex
Ex-Current Ride: 1991 Toyota Levin Gt Apex(Written Off)
Previous Ride: 1989 Toyota Starlet XL
RevolutionStarlet89
Postby sergei » Thu Jun 14, 2007 4:02 pm
Minimize the lenght of your ground cables. Ground head deck straight to body. Ground amp straight to body.
Postby bbq1988 » Tue Jun 26, 2007 10:35 pm
Hey, i had the same problem... It turned out to be one of my amp's had a bung channel
Baked, Not Fried.
bbq1988
Postby jafa.and.proud » Tue Jun 26, 2007 11:37 pm
Does the noise change or get louder or higher pitched or anything when the revvs are higher? If yes, alternator whine. If no, and as only on radio, might be something to do with your headunit or your aerial? I would ditch the noise thingee you bought though, doesn't seem to be helping
First thing with something like that is to check all your grounds are mint, as in short and grounded to bare metal (sand off any paint if theres paint where you ground)
1997 Jaguar XJ on 20s
1993 Mitsi Mirage Cyborg
Ex - 85 Corolla GL (EE80)
jafa.and.proud
Postby Caribeena » Wed Jun 27, 2007 8:12 pm
how close are your power wires to your rca or speaker wires? normally they should be run down seperate sides of the car or have a bit of space between them...
Caribeena
