Changing Rear door speakers in GT-T
Postby bbq1988 » Thu Aug 23, 2007 1:04 pm
Hey guys, anyone done this yet? similar to the front doors?
Harley
Baked, Not Fried.
bbq1988
Postby bbq1988 » Thu Aug 23, 2007 1:10 pm
Posted in wrong section :(
Baked, Not Fried.
bbq1988
Postby WCKWGN » Thu Aug 23, 2007 1:35 pm
i have 16cm sony xpold compents in all four doors running off 444w amp
only need to trim a couple of mm from the factory hole diameter to make them fit in snug
for the rear i have run the tweaters up to the top of the b pillar ( removing the seat belt gaurd etc ) facin to the back passengers
pretty easy heaps of room. any you dont need to cut any of the factory door skin to do so . so stealth appearance 8)
WCKWGN
Postby bbq1988 » Thu Aug 23, 2007 1:44 pm
yeah, ive got 2 sets of fusion encounters (6.5") and will be running them off a panasonic 4ch 1000w (250 RMS P/C)
should sound aright.. gota sort out a new sub yet :)
Baked, Not Fried.
bbq1988
Postby WCKWGN » Thu Aug 23, 2007 2:56 pm
i have taken my subs out. to heavy and not practible with the hound in the back
i now have to sell up the sounds 8)
2 x 12" subs , running 300w amp each , amps mounted to the back box, carpeted im mid/dark grey . non ported
good luck with your install. i had to remove rear number plate and foam back it to stop the rattle of it with the bass. you may find a similar prob
sounds or speed.... speed won the battle in my wagon :lol:
WCKWGN
