Help With Power Antenna - Unusual...
Postby D-T » Wed Sep 12, 2007 9:14 am
Hey all
in need of some help on this one.
I've had a VDO Dayton Headunit installed previously, and it has worked getting the power antenna up. I've replaced it with a JVC headunit, using the same wiring, and its not putting the power antenna up. I've measured the output on the 'power antenna' cable and its putting out 12V, and i've also measured the power at the antenna end on that same cable, also 12V, so why is this headunit not putting the antenna up? whereas the VDO one did?
anyone have any ideas? i'm kinda stuck! :(
+ no rock in the car on the way to work == mega poos.
thanks
94 Curren - 15.84 @ 90.9Mph
1977 MS85 Toyota Crown, Mustard Yellow, and Just as Fast!
D-T
Postby D-T » Wed Sep 12, 2007 7:53 pm
yeah mate came round had a look at the unit, pos. tested every way to get it to work, no luck so hes taken it back ++ money back. was a nice one too. grr
D-T
Postby Lloyd » Sun Sep 16, 2007 5:48 pm
Did it have 12V there under a load? ie when connected to the antenna and turned on?
Failing that you could have used the output to trip a small relay and used that to power the antenna directly from the battery, assuming it had enough grunt to do that
