No Memory - Sony head unit into Curren
Postby eskimo » Mon Dec 03, 2007 10:21 am
Hey,
Just installed my sony head unit into my, testing it out found it has no memory and wont save the radio stations remeber its on cd/mp3 etc, Im sure I have two wires mixed up but not sure what ones.
Can any one shed some light, Let me know if you need a pic of the loom I have wired in
Cheers,
JH
"If in doubt, flat out" Colin McRae 1968-2007
Current:2003 Legacy 3.0R Spec B
Previous: ST185 GT4, SW20 MR2, ST206 Curren, AE111 Corolla GT
eskimo
Postby Rob_GTZ » Mon Dec 03, 2007 10:38 am
You haven't connected a Constant 12v, Yellow wire on your headunit needs power all the time. Red wire only has power when key is on
Rob_GTZ
Postby crazed_silvertop » Mon Dec 03, 2007 10:40 am
You have the wires for the battery and accessory mixed up - find them, and swap them - then you should be sweet I would think. (Or maybe you havent attached the battery wire properly.
'89 MR2 AW11 - Silvertop..... fun :)
crazed_silvertop
Postby eskimo » Tue Dec 04, 2007 12:58 pm
Ah HA, swpped the yellow wire with the red one... all fixed. Cheers :D
eskimo
