Sony Head Unit Wiring
Postby xsspeed » Sun Jan 06, 2008 5:38 pm
Hey im putting a sony CDX F5500X head unit into my corolla.
It was originally in my old falcon that got written off, ive got the wiring diagrams from both cars so i can kinda work out which wire is which, but i dot hv ethe wiring diagram for the head unit. The guy that put it in never gave it back to me.
So does anyone have one, or know where i can get the diagram?
Postby xsspeed » Sun Jan 06, 2008 5:53 pm
Postby Mr.Phreak » Sun Jan 06, 2008 6:42 pm
Manuals Paradise is fine, but a bit overkill for what you're after probably.
Did you want to know what colour wire is what?? or don't you have the loom or something??
Mr.Phreak
Postby postfach » Sun Jan 06, 2008 8:27 pm
Are you asking what colours do what from the Sony loom? AFAIK most aftermarket head units use the same colours:
Red - 12V Ignition
Yellow - 12V Battery (Constant)
Black - Ground
Blue - Remote
White - Left Front +ve
White+Black - Left Front -ve
Grey - Right Front +ve
Grey+Black - Right Front -ve
Green - Left Rear +ve
Green+Black - Left Rear -ve
Purple - Right Rear +ve
Purple+Black - Right Rear -ve
If you need a diagram:
http://installdr.com/Harnesses/Toyota-Wiring.pdf
postfach
Postby xsspeed » Sun Jan 06, 2008 11:44 pm
yeah t hats what i was after cheers
