2008 Toyota Highlander Stereo info
Postby aliluya » Sun Jan 13, 2008 11:21 pm
Does any one know any details about the Highlander Limited edition.
I would like to change all the speakers and add a sub, is there exisiting amplifiers and what are the speak sizes and what sort are they, does the headunit have pre out's etc.
Thanks
Ali
2008 Toyota Highland 4WD LTD is awesome!!!
2001 E39 530i BMW
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1727
aliluya
Postby ThundaChild » Thu Jan 17, 2008 9:00 pm
Save yourself some greif and get a professional installer to do the job for you....Atomic Audio in Dunedin has a trained installer in the gear to do it right......Speakers are easy to swap out but beware there are alot of fctory units that run low impedance speaker outputs that will shag themselves when replaced by good new gear....
ThundaChild
Postby aliluya » Fri Jan 18, 2008 10:28 pm
Yes it is to be installed by pro's however i need to know what speakers to purchase before it is installed.
2001 E39 530i BMW
aliluya
Postby snwtoy » Fri Jan 18, 2008 11:21 pm
ThundaChild wrote:Speakers are easy to swap out but beware there are alot of fctory units that run low impedance speaker outputs that will shag themselves when replaced by good new gear....
eh? car stereo speaker standard is 4 ohm. I doubt you'll find anything lower than that in a car, and even if you do, replacing with a higher impedance is highly unlikely to damage the source unit.
snwtoy
Postby Mr.Phreak » Sat Jan 19, 2008 12:12 am
snwtoy wrote:eh? car stereo speaker standard is 4 ohm. I doubt you'll find anything lower than that in a car, and even if you do, replacing with a higher impedance is highly unlikely to damage the source unit.
Heh, beware Bose in cars, most things don't like running a half ohm load.
No idea about the Highlander though sorry.
Mr.Phreak
Postby ThundaChild » Sat Jan 19, 2008 11:37 am
My point was to see the pro to get the correct speakers for your vehicle,
size in depth and circumference is different for almost each vehicle and some aftermarket audio manufacturers only make standard sizes...
ie: 4" shallow mount fittings narrow down your options hugely and only top end audio manufactureres may have a bolt in option......best have the panels off and see what mounting, depth and other restrictions are there in reality, not what is `thought` of by others...my reference is personal experience......you wouldn`t go into ripco and ask, they would sell you whatever is on the shelf and the most expensive!
ThundaChild
Postby snwtoy » Sat Jan 19, 2008 12:03 pm
Mr.Phreak wrote:Heh, beware Bose in cars, most things don't like running a half ohm load.
True, but that would be 'lower' impedance, not higher, would it not?
Whose bose system did you blow up? :lol:
snwtoy
Postby snwtoy » Sat Jan 19, 2008 1:09 pm
ThundaChild wrote:My point was to see the pro to get the correct speakers for your vehicle,
True that, depends how confident you are about taking apart what looks to be a brand new vehicle. On slightly older vehicles it's very easy to take panels off and work out what's what.
snwtoy
Postby aliluya » Fri Apr 04, 2008 5:15 pm
Does anyone know where i can get a copy of the wiring diagram for the 2008 highland with GPS navigation unit?
Have just purchased the car and gone to the dealer to check out the navigation unit it doesn't have any rca outs or anything like that.
Or even better does anyone know whether i can purchase/downloading/view the diagram CD for the 2008 toyota highlander LTD edition.
2001 E39 530i BMW
aliluya
