Caldina Stereo Cut Out
Postby jakelanauze » Sun Sep 28, 2008 9:13 pm
any help on this would be great.
My pioneer headunit in my caldina has started randomley cutting out when driving, i.e, turns off then back on in a matter of seconds like the acc. wire is loose, I checked this and its not, also has good earth.
and sometimes when you turn car off then back on, it resets, like when you disconnect the battery.
any ideas anyone.
Thanks
I Void Warranties
jakelanauze
Postby DeeCee » Mon Sep 29, 2008 1:53 pm
first check to see that your fuses are fully intact.
If not, then I'd be inclined to think that is a loose connection inside the unit that could be the problem if its not the wiring of the headunit to the car itself.
GT Four Adovansu
DeeCee
