12" sub box
12" sub box
Postby ihavelift » Sun Nov 29, 2009 10:54 pm
So i bought a 12" sub (400w rms), and need a custom box made as most premades won't fit in my boot.
Does anybody know where i could get a good box made for a good price or alternatively have a box that would house a 12" sub in a celica boot?
Current: 2000 Honda Accord Wagon CF6
Previous: 97 Toyota Celica GT4 ST205; 2001 Toyota Allex RS180, 96 Nissan Sentra SG
Low, Slow, Clean and Mean
ihavelift
Postby Bling » Mon Nov 30, 2009 12:51 am
Got the following?
Ruler,
Pencil,
Saw,
Wood glue,
screws,
time?
Buy a sheet of customwood and build one yourself, not hard 8)
Re: 12" sub box
Postby sergei » Mon Nov 30, 2009 9:02 am
ihavelift wrote:So i bought a 12" sub (400w rms), and need a custom box made as most premades won't fit in my boot.
If you still want to have boot left, 12" will be difficult to fit.
I resorted for 10" instead, non right angle wedge to go in the left side of the boot. The 10" would have ~5mm off the bottom of the box (before magnet hits the floor of the box). Width wise there should not be a big problem to fit a 12", but depth wise it is very difficult unless you want to sacrifice boot space (that is tiny to start with).
I can take pics of my box if interested.
I used card board to make a mock-up and then used trig to recalculate all the angles, length and cuts properly (as there is no 90' angles in there). I also used whole load of screws, and epoxy resin (glued and coated inside an out) but that was over kill.
