running rca splitters
Postby deaf_rattle » Thu Mar 11, 2010 8:22 pm
when splitting the signal, does it reduce the quality or power of the signal?
or not really noticable?
Postby DeeCee » Thu Mar 11, 2010 9:02 pm
you're fine running splitters. I'd explain, but then i'd get told off for over explanation :lol:
GT Four Adovansu
DeeCee
Postby deaf_rattle » Thu Mar 11, 2010 9:05 pm
DeeCee wrote:you're fine running splitters. I'd explain, but then i'd get told off for over explanation :lol:
lol, all good man.
Just the head unit i might run to start off with only has front and rear preouts 4v though.
so i might run the fronts and rears with splitters and sub off the rear for now.
Postby DeeCee » Thu Mar 11, 2010 10:15 pm
depends on how you want to fade, or if you fade at all.
some amps have an auxillary output on the amp itself, so possible option there as well.
GT Four Adovansu
DeeCee
