Trying to install a sony head unit into a 1992 Land Rover Discovery - I have all the wires except the Aux wire.
The yellow is the main and it also has an orange companion, which from the factory unit plug are right next to each other, however there is no power feeding through once the key is turned.
I wouldn't imagine this is a fuse as i wouldn't be getting power from anywhere if the fuse was blown.
I have tried all the other misc. wires but to no avail...
The main has a wire splitting off it which is also feeding a constant current but I think this is for the ariel - can i tap the aux from the head unit into this? I would assume this means the stereo would stay on all the time then?
Any ideas what I can do to fix this?
