ERR 1 (HDN-061 6-cd stacker issue)
Postby Scrunty » Mon May 17, 2010 2:36 pm
Having this error message popup on my factory six disc :(
CD just happened to try to change to the next cd as I went around a corner (reasonably 'fast')
My google-foo is obviously not up to scratch as I can't find diddly.
As for the searching these forums it never ever seems to pull anything even close to relevant?
Have tried emptying the mag and letting it cycle through the empty slots (in the hope it might reset itself if that makes sense)
And have tryed just using one cd in various slots but getting the same message every time.
Is there any hope or do I have to resort to replacing the whole headunit? :(
<97 JDM gen4 G-Limited MR2>
SW20 g4 n/a
Scrunty
Postby mr30%jr » Mon May 17, 2010 5:22 pm
no cds fell inside it?
mr30%jr
Postby Scrunty » Mon May 17, 2010 11:22 pm
Nope, all 6 were still in the mag :?
SW20 g4 n/a
Scrunty
Postby Sick Puppy » Tue May 18, 2010 1:37 am
Well, from the reading here using my google-fu:
http://www.howtomendit.com/answers.php?id=185102
It could be a fault in the loading sensor that tells the player there are cds in it, so it should start the motor to spin the disc. But then there are people on this forum much more knowledgeable than I am, and I'm just playing with my google fu mastery! lol What are the model numbers for the stacker and head unit? Should be two five digit numbers with a dash in between, or alternatively a five digit code beginning with C? There is a guy in Palmie who deals in these, if you still want an OEM set, I can flick you his details?
The stock answer with OEM stackers and head units in general though, is that once not working properly, they are toast and not worth repairing (especially at stealership prices 8O ). I replaced mine as the stacker had a missing cartridge and the lights went funny on my head unit, but always wondered about the OEM one... so when I found a cartridge for it, I had to swap them back around. Came up ERR3 first time. :oops:
Project thread here
Discussion thread here
Sick Puppy
Postby Scrunty » Wed May 19, 2010 7:52 pm
Thanks, might have to crack it open on the weekend for a looksee
SW20 g4 n/a
Scrunty
