Ive been thinking about this a bit more, and (as much as I hate to admit it) Ive sort of changed my mind.
I think the intent of the original question has been lost in the wording, and the wording in its current state is an ambiguous impossibility.
I think the original intent of the question was probably "Could the plane take off, if the conveyor moved at the same speed as the *plane* in the opposite direction"...
As I am quite sure that the intent of the original question was a simple question about relative speed, more than anything else.
In which case the question and answer are very simple.
Yes, the plane takes off, and the wheel speed is double the plane speed.
However, the problem with this question, is that the conveyor doubles the WHEEL speed,
what ever it is.
Ignoring everything else, the problem boils down to "wheel speed = wheel speed x 2."
As opposed to "Wheel speed = plane speed x 2"
If the plane is stationary, and wheel speed = 0, then nothing happens.
But if the wheel moves even 0.00001mm, (eg, an ant farts on the wheel) then the wheel speed increases and increases towards infinity.......
It wouldnt keep on increasing until the force is equal to the thrust of the jet engines....
As this would imply, that at a certain wheel RPM, the wheel speed would stop increasing by 2.
The wheel speed would keep on increasing, until it surpassed even the forces generated by the engines.
So the plane would be spat off the back of the runway, as the wheel speed and conveyor speed would increase and increase.
Either way, we are forced to make assumptions about the complexity of the question.
Do we assume that they really meant to say "plane speed" instead of "wheel speed"?
Do we assume that the plane is invincible, and can widthstand all of these forces?
Do we assume that the tires wont slip?
Do we assume that the conveyor and wheels can spin to infinity?
Since the conveyor and the wheels are spinning at an infinite speed, do we assume that they turn into pure energy?
If we are assuming that the friction of the wheels holds the plane back, part of the friction is heat. infinite speed = infinite friction = infinite heat. What are we to assume about this? Does the conveyor melt the universe?
I think that all of these questions cant be answered, and I think that none of this was intended in the original question....
It is probably the chinese whisper rewriting of the question that has caused the dispute, as a simple change of 'wheel speed' to 'plane speed' changes things completely.
It seems like a simple question that someone would ask, similar to "If I am travelling at 5,000kph, and fire a bullet at 5000kph behind me, does the bullet drop to the ground?"
The problem being that in this case, a slight change in wording completely changes the scope of the question from simple and plausable, to horribly overcomplicated, and impossible to answer without some very crucial assumptions being made.
EDIT:
Thinking about it some more, it depends totally again on the wording of, and how they define "matches the wheel speed" for the conveyor.
If you think about it, if a wheel is rotating to move at 10kph on flat ground, then relative to the wheel, the ground is moving backwards at 10kph already.
If this is the interpretation of "matches the wheel speed" you take, then the plane will take off, as the conveyor belt wont move at all.
