Dr-X wrote:[V8ROLA] wrote:and wait for the SV6Tthat will give the XR6T a run for its money
Yeah, but the Typhoon will still womp it good.
What makes you say that? The specs gaven't even been released - and the NA SV6 outperforms the NA XR6.....
im sure its setup a certain way so they do have effect's on it.
eg 2 larger gear's spinning them rather than a faster one, reason being, MORE boost in the high end, id imagine that engine is seutp for an amazing amount of boost.
CozmoNz wrote:thats like people saying *nah, 1 turbo is way better than 2*
go tell that to the chap with the twin turbo rotor.
dont see many FORD powered chevy's round do you
plus he also has an 8/71 (568 cuin) feeding into a 6/71 (426cuin) so unless he is feeding them at a ratio that will drive them at the same speed (which i would understand to work) he will be trying to push 568cuin threw a 426cuin hole now like i said unless he is under/overdriving one our the other there will only be as much air as the 6/71 is going to push threw hence my point that a 6/71 will do exactly the same as that setup.
yeah exactly he builds SHOW cars and he is dam good at it i can name afew past winners that are as good as he is as well.
ras kongo wrote:I think youll find that guys who are going for some serious power will use one huge turbo rather than two turbos.
Check out all the drag skylines and rotories, most will have one big turbo.
Err, I've probably seen more ford powered chev's than vice versa
[V8ROLA] wrote:and i thought i did mention his CHEVROLET powered burnout champion winning burnout mustanghence CHEVROLET POWERED!!!!.
