sergei wrote:Plane will take off.
But the speed of the conveyer will depend on the plane's speed (if the contradicting statement is resolved) becuase of the friction of the wheel against conveyer and wheels are attached to the plane.. (think about bearings - the actual ball/rollers/needles rotate at a speed relative to to both outer and inner shells)
sergei wrote:So what I'm trying to say is:
The speed and ability to fly of the plane are NOT affected by conveyer.
The conveyer speed IS affected by plane's speed due to friction in wheels/ wheel vs conveyer and fact that wheels are attached to the plane.
The speed of the conveyer will be double but in opposite direction of the plane or will be same as plane's and in same direction deppends how the conditions are interpreted.
sergei wrote:But belt sander is not desgined to match "speed of the wheels"! and any way it will require the same force as to move with same speed relative on the ground (ie if a point on the belt sender doing 5m/s relative to the car, it will require same force to move the car on stationary sand paper with car having speed 5m/s relative to that sand paper)
sergei wrote:I sometimes follow simple rule:
If problem does not have a correct answer - change the problem so it will...
V8MOFO wrote:sergei wrote:I sometimes follow simple rule:
If it were that simple it wouldn't be a very good question. Because there is no answer because it is impossible makes it a very good question, hell 15 pages on good question.
igor wrote:V8MOFO wrote:sergei wrote:I sometimes follow simple rule:
The original version of the question where the conveyor matched the aircrafts groundspeed was better. :/
