Calling all Gen II MR2 owners...
What do you run on ya MR2
Aftermarket ATMO bov
4
50%
OEM or Aftermarket plumb back
2
25%
Neither because an aftermarket jobby blew my engine
2
25%
Total votes : 8
Postby KiwiMR2 » Tue Apr 13, 2004 10:06 am
Do other makes using AFM's suffer the same issues as the MR2s with relation to over fueling when running aftermarket atmo bov's??
I ran one on my Gen II for a couple of years with no problems except it ran a LITTLE bit rough on gear changes compared to the oem plumb back. Im pretty sure Torz is still running it with no issues.
KiwiMR2
2003 Estima 3.0L
2000 Opa
KiwiMR2
Postby MrBob » Tue Apr 13, 2004 12:31 pm
yeah, i ran external venting one for couple of years. No problems. When i first put it on would blow some nice flames on de-acceleration, due to a lil over fueling. Stopped after a while, assumed the ecu made a small adjustment ? who knows.
..have since converted to map sensor, but can still make it backfire by feathering the gas as the bov is dumping :mrgreen: yay for flames
mates rx7 did exactly the same thing when he fitted extrnal dumping bov
MrBob
Postby Dell'Orto » Tue Apr 13, 2004 1:29 pm
Umm, I fitted the Blitz one at the same time I did the LinkPlus, so I've never had any issues with it.
Postby Al » Tue Apr 13, 2004 9:58 pm
I occasionally vent the facto one to the atmosphere and the car runs like utter crap, i block up the return pipe with a 1.5 litre coke bottle lid and just put the pipe outta the way. The thing leaks occasionally while its venting to the atmo so it may be just that my facto BOV is farked.
BTW KiwiMR2 i thought you had a Gen1 (1989-1991) before the Gen3 since it had the 14"s ?
Al
Postby KiwiMR2 » Wed Apr 14, 2004 1:10 pm
Al wrote:BTW KiwiMR2 i thought you had a Gen1 (1989-1991) before the Gen3 since it had the 14"s ?
First up I had a 1990 G-limited with the factory 14's, then A 1990 GT with aftermarket 16's, now a Gen III with factory 15's.....so yeah, Gen I but hey G1 & G2 are much the same.
KiwiMR2
2003 Estima 3.0L
2000 Opa
KiwiMR2
Postby Twolitre » Wed Apr 14, 2004 1:49 pm
Turbosmart Supersonic BOV on my ST205 because that's what it came with.
No BOV on my ST185 because that's what it came with :wink:
Unless you've got a fragile (ceramic) turbo you don't need a bov, not even a stock one on a GenII even on higher boost.
Twolitre
Postby Jools » Thu Apr 15, 2004 2:22 am
I run an atmo BOV on my genII st185 and it would sometimes stutter badly after backing off and gunning it again. Makes sense that this would happen with the stoopid AFM.
Going to MAP now so its not an issue.
But you can get a 50/50 plumb back / atmo BOV now which leaves some air in the system while venting enough to make the PSHHH noise we all know and love :D
90 Celica GTR Turbo
184kw @ 14psi at the front wheels (Now running 17psi watch this space for dyno :) )
"Owner of the fastest Celica GTR in NZ (Until proved otherwise ;) )"
www.Jools.tk
Jools
Return to Polls
Users browsing this forum: No registered users and 121 guests
