Page 1 of 5
When it comes to cars what can you do / have you done.
Posted:
Tue Jan 17, 2006 8:30 pm
by Adydas
Simple intrest poll, Please be honest as votes will only lie to your self.
Any bickering or negative comments will result in a lock by me and i am intrested to know the stats from this.
So please IF you REALLY have to comment keep it clean.
I can only assume your vote means you can also do the stuff below to.
I assume mates gave a hand as no one can carry a gearbox alone unless
Posted:
Tue Jan 17, 2006 8:32 pm
by FrEsH
standard installer i'd say as i haven't tried to chagne a clutch/engine etc yet...haven't had to
Posted:
Tue Jan 17, 2006 8:37 pm
by 2LTR Rona
Engine swapper / Gearbox changer / Clutch fitter I would say moving more towards the other two i.e. currently rebuilding my Capri from the ground up (with help here and there) and will then move on to the KE25 with the engine swap
Posted:
Tue Jan 17, 2006 8:50 pm
by Adydas
we all are a talaented bunch of buggers arnt we :p
Posted:
Tue Jan 17, 2006 8:54 pm
by MINTFX
Standard installer here, but I have replaced my own clutch, fuel pump and other crap. I could probly do an engine swap with the right tools and directions. I have pulled a motor apart aswell, didnt put it back together though as it had a huge hole in the side of the block
Posted:
Tue Jan 17, 2006 8:56 pm
by Emperor
I'm inbetween Basic and Standard. I can do my own sounds, pod filters, oil changes, etc
Though I do admit I ask for help on most stuff.
Posted:
Tue Jan 17, 2006 9:01 pm
by supradave
When it comes to my car im not to bad but give me basically anything else, especially different make im lost. and dont get me started on subaru's
lol
Posted:
Tue Jan 17, 2006 9:03 pm
by Malcolm
as far as my own cars go, I know them almost inside out and do almost everything myself (except machine work - since I don't have the right machines, and wheel alignments, because I don't have an alignment rig
If I was to perhaps have someone throw a 2005 Audi at me or something, I think I'd be fairly lost...
Posted:
Tue Jan 17, 2006 9:32 pm
by RomanV
All_Fours wrote:
If I was to perhaps have someone throw a 2005 Audi at me or something, I think I'd be fairly squashed
Corrected!
I can do a few things, but Im definitely not at the same level as someone like Malcom or Vvega... Much respect.
Im getting there though, still learning new things all of the time.
Posted:
Tue Jan 17, 2006 9:41 pm
by Dell'Orto
I can do most things myself...have done engine builds (nothing particularly high tech, 12A 6port would be about the trickiest). Done engine, clutch, gearbox and diff changes.
Only things I can't do are similar to Malcolm...and fabrication, cause I dont have a welder
[/b]
Posted:
Tue Jan 17, 2006 9:48 pm
by Malcolm
RomanV wrote:All_Fours wrote:
If I was to perhaps have someone throw a 2005 Audi at me or something, I think it would ricochet off my manly chest and land in a quiverring heap in the corner!
Corrected!
Double-corrected!
Posted:
Tue Jan 17, 2006 10:05 pm
by V8MOFO
I can install I.C.E and change a tyre.
I'm the MAN.
Posted:
Tue Jan 17, 2006 10:25 pm
by Santa'sBoostinSleigh
currently im an installer, but with my racecar im moving towards engine swap!
a few more tools and a bit of guidance and i'll be there!
Posted:
Tue Jan 17, 2006 10:33 pm
by Alex B
On the low side of 'Engine swapper / Gearbox changer / Clutch fitter' if that makes sence.
Posted:
Tue Jan 17, 2006 10:36 pm
by vvega
Posted:
Tue Jan 17, 2006 11:11 pm
by 3VLTOY
Done an engine swap and manuel conversion but did have a friend there teaching me as i went.
Brake pads, oil change etc. are a piece of piss to do on my own.
Prefer to buy the parts and do it on my own or have someone showing me how to do new things
Posted:
Tue Jan 17, 2006 11:54 pm
by Brick
done clutch, head gasket, taken engine apart and rebuilt it with guidance, brakes and other minor things
Posted:
Wed Jan 18, 2006 12:44 am
by Boosted_162
I have no problems putting things where they are designed to go, eg swap a gearbox etc. But when it comes to putting things where they arent designed to go (aka vvega and his 1UZ AW11) i get lost.
Posted:
Wed Jan 18, 2006 7:26 am
by DJ
Have a guess...
Posted:
Wed Jan 18, 2006 7:43 am
by EVL GSXR
DJ wrote:Have a guess...
I put Basic and Standard..
Own Stereo, Brake Pads, Filters, Oil Changes, Boost Controllers etc etc
