diss1dent wrote:imo a 1jz would ruin the handling and balance of a 86
Silent Knight wrote:ResTecPa!!!!![]()
Adamal wrote:This is XRyanX. His car is so low that he has to drive over speed bumps diagonally. HARDEN THE $$% UP XRYANX!!
Ako wrote:You missed the 20b option, so I ticked the next best thing
xRyanx wrote:Im sure most of you have seen the video of the 20b 86. That thing is silly fast. Id rock a 20b if i was doing a rota swap
Jebus wrote:In New Zealand its a bad idea, because the majority of New Zealands rotarys are built for noise, cost $200 to build with second hand parts and thier cousins mates boyfriend ported it with a die grinder. If this is why hes doing it, and im geuss he is from the style of your thread and how you spelt 'rota'.
Over seas they build rotarys properly, there are rouglhy 4213423 aussie street rotarys running 10's and below.
What im getting at is if he wants a sh*t load of power (i.e more than can be made from an A or S series motor comfortably) and wants to keep the engine compact and small with no chopped firewall etc. then by all means...
If he wants a 'rota' cos 'rotas' are cool then tell him to get a DX.
ke25sr wrote:Jebus wrote:In New Zealand its a bad idea, because the majority of New Zealands rotarys are built for noise, cost $200 to build with second hand parts and thier cousins mates boyfriend ported it with a die grinder. If this is why hes doing it, and im geuss he is from the style of your thread and how you spelt 'rota'.
i see were you are coming from..
he isnt doing it for power ats is a stock standard 12a turbo without a turbo.
taking out a 3au and replaceing it with a good running 12a
that hasnt been touch by some dumb hick $&#$%
i started the thread because he has had a bitch of a job with making a firewall, trans tunnel... When he started i told him to go 4age it would be easier he argued withme so im trying to prove a point.
you just read to deeply into a misspelt word.
wank-el
