bbq1988 wrote:I Think that climate change is due to the earths habit of "Resetting" its self every xx,xxx,xxx+ years. Its happened before, it will happen again.
+1 for SCAM
holden_fan2005 wrote:bbq1988 wrote:I Think that climate change is due to the earths habit of "Resetting" its self every xx,xxx,xxx+ years. Its happened before, it will happen again.
+1 for SCAM
I agree.
I bet it's just the earth cycle. Maybe cars make the cycle happen faster but it's going to happen no matter what.
sh*t for all we know we may be the 5th or 6th or 10000th generation of humans on this planet.
No I'm not into science and I know I'm more than likely wrong about everything, but that's my opinion.
Gonad wrote:It was a while ago, but in 5th form science I'm pretty sure we learnt about the correct way to carry out an experiment. Dont quote me but doesnt it go something along the lines of hypothesis - test - result, and the result tells you whether you are right or wrong, and from the result you modify your hypothesis? These exposed emails seem to tell us that 'world leading scientists in global warming' believe you go hypothesis - result - tests to confirm hypothesis, if the results from the tests dont fit, then discard, cover up or manipulate.
Finally people are starting to wake up, how refreshing. The IPCC is a completely corrupt entity, made up with people who tow the line, if you dont tow the line you're out, so we have this completely biased one sided 'authority' on the issue who everyone listens to without question.
I am in no doubt that there is climate change, as some have pointed out the earth's temperature is always changing, I think that human activity probably has some part to play, but I see no concrete proof that it plays as much of a part as the IPCC would have you believe. In the same way Bush had a vested interest in Iraq, the movers and shakers in the Global Warming scam will do very well if the world believes in the crap they are peddling, Al Gore is on his way to being 'the first global warming billionaire'. Neutral? I think not.
soniq wrote:ignorance is bliss for some people i guess
Adamal wrote:...... HOT TOPIC????
That is terrible......
fivebob wrote:Adamal wrote:...... HOT TOPIC????
Just like may favourite tee-shirt which reads... Goblal Warming, All the coolest planets are doing it.
Mr Revhead wrote:fivebob wrote:Adamal wrote:...... HOT TOPIC????
Just like may favourite tee-shirt which reads... Global Warming, All the coolest planets are doing it.
hell I want that one
