black top 20v
black top 20v
Postby yo_dookie69 » Fri Mar 26, 2004 8:19 pm
ok u gota pretend i know nothing about cars, cos really i dont.
wot r the first things to do to a ae111 to work it up a bit
i put a pod filter on myself but im sure it made it slower, and if also heard that u cant really work then because most of there power comes from them being tuned so finally.
ne help would be good
yo_dookie69
Re: black top 20v
Postby skoty » Fri Mar 26, 2004 9:11 pm
yo_dookie69 wrote:i put a pod filter on myself but im sure it made it slower
What type & brand of poddy is it?
Where is the poddy mounted off the throttle body?
Has the ecu been reset after this modification?
skoty
Postby Bazda » Sat Mar 27, 2004 7:28 pm
I have 3 mates with ae111s and putting a pod filter takes away the bottom end power for some reason, on all 3 of them!!, and yes it had cold air going to the filter.
But it sounds nice so they dont care.
Postby Levin111 » Sat Mar 27, 2004 11:13 pm
lol,
any way, umm fst thing i would reccomend is getting a aftermarket exhaust system, they are always good. then maybe start doing response stuff like new leads ?. then you can start fiddling wif ecu and stuff.
New Profile Update:~
http://toyspeed.blakjak.net/profiles/profile.php?id=298
Past rides
Levin Ae11 BZ-G
Rx7 S6 13b REW
Mazda 929 wagon
Rx7 S4 13b Extend port turbo (Current)
Levin111
Postby 4agepwr » Sat Mar 27, 2004 11:44 pm
then after these u got to into head work such as cams maybe even timing
Jappa AE82 Corolla GT Sedan
EX: AE82 NZ New Corolla GT Liftback
4agepwr
Postby qik20v » Tue Mar 30, 2004 6:15 pm
and a new ecu for agresive cams, then you realise you have spent so much money you might as well have turbo'd it from the start
1996 AE111 Toyota Levin BZ-G - 15.1 @ 146km
http://toyspeed.blakjak.net/profiles/profile.php?id=301
qik20v
Re: black top 20v
Postby 4ageLova » Fri Apr 09, 2004 7:19 pm
So how do you reset the ecu??
What effect does resetting ecu have??
Thx
'96 Trueno AE111
20v BlackTop
4ageLova
Postby JRS » Fri Apr 09, 2004 8:02 pm
u cant mount a pod of the throttle body, it has 4!
meh.....
JRS
Postby 4ageLova » Sat Apr 10, 2004 12:24 am
JRS wrote:u cant mount a pod of the throttle body, it has 4!
Does anyone have a picture of such setting??
I can't imagine how one can put a pod filter on individual throttle body.
Maybe they have small ones.
Thx
'96 Trueno AE111
20v BlackTop
4ageLova
blk top mods
Postby ROBODISCO_20v » Sat Apr 10, 2004 2:12 pm
We'll i'll tell you what mod's that have been done on my blk top.
HKS pod, NGK iriduim plugs(bkr6eix11), 7mm leads, Full Mandrel bend Exhaust with two hot dog style resignators and small stainless muffler at the rear. High lift cams/I dont know what the are but they have given the engine a much broader power range, they give heaps more torque down low & starting from 4000 and pull hard right thru to the 7900 rev limiter. I'm still running the factory ecu with all these mods. I've driven a few other 111 with intake & exhaust mods and i'd leave them for dead. I'd have to say the mod thats made the biggest difference has to be the cams. it's not the cheapest mod but by far the best i've done. i also found the iridium plugs helped up top, made it rev more freely.
Take from this what you will,im not saying its the only way to mod a blk top everyone has different ideas, but this set up works for me. I will have some dyno figures in the next month or two when i get my licence back. then some 1/4 mile times to do.
ROBODISCO_20v
Re: blk top mods
Postby B1NZ » Sat Apr 10, 2004 8:00 pm
ROBODISCO_20v wrote: I will have some dyno figures in the next month or two when i get my licence back. then some 1/4 mile times to do.
YES YES, get these figures as this sounds like an interesting setup and i'm looking foward to seeing how it all pans out, I'd like to see a Blacktop running 14.0-14.5's because people say it cant be done :wink:
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Re: blk top mods
Postby MattrickMotorsport » Sun Apr 11, 2004 10:48 pm
Damn if my blacktop dont run that im seeling it! 8O
MattrickMotorsport
Re: blk top mods
Postby B1NZ » Mon Apr 12, 2004 11:25 pm
Wow, that looks like a machine, how heavy is the FXGT in that shape? Assuming its fairly lite you should get there or at least get close(assuming you can drive) My Levin has 95.5kw@wheels with 1040kgs and runs 14.9's so your beast should be able to do this?
Subaru GF8 Wagon
B1NZ
Postby MattrickMotorsport » Tue Apr 13, 2004 8:09 am
Class weight limit is 850 so will be aiming to get as close to that as possoble :)
MattrickMotorsport
Postby ROBODISCO_20v » Sat Apr 17, 2004 5:16 pm
FXGT ??? I got a BZG levin.
I've only seen the Corolla in 4dr sedan & 5dr S/W. I'm not sure they make a 2dr hatch back in the ae111. Yes they do, the WRC corolla was an ae111, wasn't it and that was 2 dr and i've seen pics of them in england. but they're equiped with puss box 4afe.
ROBODISCO_20v
Postby PoMmY » Sat Apr 17, 2004 10:08 pm
Go to www.google.com, search '4age'
Then click on the 3rd link down i think
Its called Bill Sherwoods 'modified 4age'
I think that will help a little :wink: , 500horsepower??
PoMmY
Postby RAZA » Fri May 07, 2004 2:13 pm
ROBODISCO_20v wrote:FXGT ??? I got a BZG levin.
Matrickmotorsport has a ae92 fxgt with a blacktop transplant check out the link in his profile it looks like a mean little machine
Currently driving:
BMW 135i M
RAZA
Postby matt dunn » Fri May 07, 2004 7:15 pm
Thx
Probably just put a popd on the end of the factory air box instead of the flexi pipe that goes to the factory air cleaner box.
Postby MattrickMotorsport » Fri May 07, 2004 9:59 pm
No there was apic up here once of 4 small K&N Type filters on each throttle body
IT DOESNT HELP YOUR ENGINE EITHER! :roll:
MattrickMotorsport
Postby RedMist » Sat May 08, 2004 12:05 pm
Yep it was on an Australian rally car. He used to post here and had 108kw at the wheels with similar modifications to his engine as mine, head work, aftermarket cams of similar duation and lift, aftermarket ECU, forged pistions, crank blading etc. I run the standard 20 valve airbox and injection on my 16 valve. I have 130kw at the wheels. You can do nothing but loose power throughout the rev range with individual filters. There are two Helmholtz resonators in the standard inlet system. The single filter inlet is tuned to pack air into the airbox at a certain velocity. The second Helmholtz resonator is for each TB, by removing the standard trumpets you reduce the inlet length and effectively tune the car for optimum flow at more than 15,000rpm... which you'll never reach without a custom crank let alone use as your maximum torque.
If you want wank...get some neons.
PS Normally aspirated 16 valve with 130kw at the wheels.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Users browsing this forum: No registered users and 34 guests
