Car Engine Surging
Car Engine Surging
Postby Mr. Mainstream » Mon Apr 05, 2004 1:18 pm
my car engine is surging for some reason. if im at the lights it idles at 2,000 and with rev back and forth between 2,000 and 2,800 quite a bit and it is very annoying. is there something i can try out my self to fix it or shod i go see the boys at sumner auto (im putting there kids though college) . dosnt it sound safe enuff to drive to and from work untill wednesday (pay day). Cheers.
Current:77 MK2 Ford Escort L 1.3L
75 MK2 Ford Escort L 2.1L
Had: 2X Early Subaru Leggys GT Wags, 1X Subaru RS, 1X 2004 Subaru B4, 2x BFMP Turbo Sedan Famil's, 2x BFMR Turbo Sedan Famil's, AE92 FX-GT, 97 Holden Calais 3.8L
Supercharged 12psi ,Escort, BZ-R
Various Others
RomanV wrote: Mr Mainstream: The king of the Pushrods?!
Mr. Mainstream
Postby Dell'Orto » Mon Apr 05, 2004 2:08 pm
Idle stepper motor, or perhaps the TPS is out.
Postby Mr. Mainstream » Mon Apr 05, 2004 2:09 pm
are they a big deal? how much? how could i tell?
Various Others
Mr. Mainstream
Postby MrOizo » Mon Apr 05, 2004 2:19 pm
Sounds more like a Vacuum leak :o
mgiht wanna look for leaks... usually locate them from a hissing sound..
MrOizo
Toyspeed Legend
Postby Lloyd » Mon Apr 05, 2004 2:23 pm
My old starlet had the same problem, was a gasket on the intake manifold I think. Quite possible that its a vacuum leak
Postby Mr. Mainstream » Mon Apr 05, 2004 3:21 pm
doz it sound safe enuff for me to drive around with untill wednesday?
Various Others
Mr. Mainstream
Postby Lloyd » Mon Apr 05, 2004 3:24 pm
If its a vacuum leak then it should be fine for a while. I drove around on mine til I got pissed off with it revving up and down when I was sitting at the lights (wasn't exactly a quiet car). Cruise in to a garage and get them to have a quick look and tell you what it could be
Postby Snoop » Mon Apr 05, 2004 5:25 pm
hey my mr2 had that, it was a vacuum leak, took it in for a tune and the they fixed it at the same time, you can drive it safely but get it fixed as a priority (if it does that straight from start up as mine did- bad for engine wear)
A plan so good my head would explode if I even began to know what I was talking about...
Snoop
Postby Mr. Mainstream » Mon Apr 05, 2004 5:52 pm
it overheated and started smoking in town. sitting there for dead.
Various Others
Mr. Mainstream
Postby Snoop » Mon Apr 05, 2004 8:07 pm
8O 8O come again? ceased?
Snoop
Postby Mr. Mainstream » Mon Apr 05, 2004 8:29 pm
yeah cruizing down the street you know how we be doing it, then all off a sudden the temp meter shoots straight up off the clock, the Orange engine light turns on so i pull over put the car in nuetral the car kinda stalls and the engine steams, cant be $&#$% with it.
Various Others
Mr. Mainstream
Postby Mr. Mainstream » Wed Feb 16, 2005 11:01 pm
bump. find this thread funny
Various Others
Mr. Mainstream
Postby solberg Fan » Wed Feb 16, 2005 11:36 pm
You get it fixed in the end? what was the prob?
Team KB' Racing
in association with CRC
1981 DX corolla
*My KE70*
solberg Fan
Postby Stealer Of Souls » Thu Feb 17, 2005 9:29 am
My 4AGE has had this problem three times now. Keep cooking the Cold Throttle Control bit on the Throttle body. If it happened suddenly (not developed over time), and it is a 4AGE this is the most common cause...
Does the engine still run? Or is it mush now?
'86 AE85.5 Levin
Stealer Of Souls
Postby Mr. Mainstream » Thu Feb 17, 2005 12:40 pm
Badly Blown Headgasket. weak link in 4ages i have found
Various Others
Mr. Mainstream
