wheel polishing, good place to go in auckland ?
Postby AE85.6 » Mon Apr 05, 2004 8:40 pm
i know there a number of places round Aucks that do this but anyone know of a reasonably priced place or place that did a good job and that may paint the inbetween bits black as one place i went in the past for some old toyota wheels has like tripled its price !!
or any metal polishers by trade here ???
the wheels i had in mind are some old celica/supra 15s
If you drink, and drift,
your a bloody lunatic
AE85.6
Postby AE85.6 » Wed Apr 07, 2004 2:34 pm
anyone had this done recently ?
AE85.6
Postby MrOizo » Wed Apr 07, 2004 3:05 pm
Manakau Auto and Tyre - Good guys and apparently theres some nice eye candy in the form of a nice young hot female...
i did a video for them about a year back and had a look at twhat they actually do and was impressed!
they do restorations too....
http://www.magsandtyres.co.nz/
MrOizo
Toyspeed Legend
Postby AE85.6 » Wed Apr 07, 2004 7:43 pm
cheers man will try them
AE85.6
Postby qik20v » Thu Apr 08, 2004 5:47 pm
another place to try which i found quite cheap when i rang around was a place in wairau, or nearby, i think its called metro hard chrome? they are just a small one person business and i think he said around 400 or maybe even 360.
i cant find the address at the moment but if u want it just either look it up or pm me
1996 AE111 Toyota Levin BZ-G - 15.1 @ 146km
http://toyspeed.blakjak.net/profiles/profile.php?id=301
qik20v
Postby Bazda » Thu Apr 08, 2004 6:41 pm
metro hard chrome and polisher in paruty place.
awesome dude
and very cheap
Postby rcook_nz » Thu Apr 08, 2004 10:53 pm
come on mate do they yourself its a piece of piss any fool can do it $&#$% paying someone to polish your wheels
rcook_nz
Postby Fred » Fri Apr 09, 2004 11:36 am
place that bazda mentioned dus it about 20-25 each wheel probly. Try do it urselv me and bazda gna try, cant be that hard :wink:
But its jst if u cant b botherd do it urslf i guess
White Trueno ae92, 4agte
172kw atw and as bazda put it "lowest reading dyno in auckland"
http://toyspeed.blakjak.net/profiles/profile.php?id=672
http://www.cardomain.com/ride/2124212/1
Black and Gold Trueno ae92, 4agze
14.6@152 (hmmm thats a .69)
http://www.cardomain.com/ride/2160441
Fred
Postby AE85.6 » Fri Apr 09, 2004 12:45 pm
ye might try myself but dunno if ill get the whole bling bling quality, but hey if it only costs 25ish each wheel why not
AE85.6
Postby RE20 » Fri Apr 09, 2004 3:17 pm
Anyone got any tips, products for doing this yourself/ I'd be interested :)
RE20
Postby Fred » Fri Apr 09, 2004 10:10 pm
chuk ya car on a hoist and get sum1 to sit in it and floor it in first and get sum sandpaper an a flat piece of wood and sand away and work to a real fine sandpaper then just buff the bajeepers out of it? and then maybe even clear coat it? hey its jst an idea
Fred
Postby ~KDL~ » Sat Apr 10, 2004 6:04 pm
if you are going to polish it yourself, make sure you dont heat the meta too much, it will $&#$% up your wheel completely... but to polish yourself, go get 'em acid dipped, then pul out a grinder with a polishinng bit and polish away :D
Everybody makes mistakes. Champions never make the same mistake twice.
~KDL~
Postby rcook_nz » Sun Apr 11, 2004 1:26 am
~KDL~ wrote:if you are going to polish it yourself, make sure you dont heat the meta too much, it will f**k up your wheel completely... but to polish yourself, go get 'em acid dipped, then pul out a grinder with a polishinng bit and polish away :D
what acid dipped dipping something in acid is to remove burn marks from welding or to harden steels dip ur mags in acid and ur a $&#$% fool
just get a good hand held polisher and make sure u hold it rock steady and keep it flat or at the same angle always these three polishing wheels to use a flat wheel to remove scratches and marks and a 2nd cut wheel to sand it finely and then a polishing wheel put some autolos or similar all over the wheels the add heaps of wax to the polishing wheel and always go in the same direction and angle or keep it flat just go nuts with the polish wheel remember when u think the good enough start again it will take $&#$% ages to make them look primo but its rewarding when they finally ive did a friends and spent 18 hours doing they but it was well worth it they looked awesome
rcook_nz
Postby cr1mnl » Sun Apr 11, 2004 12:41 pm
you dip them in acid to remove the old paint off them. if you try and polish mags that are painted (which most are except for old school ones) it will take you an eternity (like 18hrs) without dipping them. i had mine acid dipped before i got them powder coated to remove the paint they had on them and they came out great. stripped back to the bare alloy. i dont know where you get the idea that acid dipping is to harden steels. usually thats done by heating in a carbon solution and quenching in oil or water
the guy in parity place is the cheapest around afaik, and its more like $80-100 per wheel not $20-25. you can get powder coating done for $25 and they have a full range of colours including a polished/chrome colour but that costs a bit more
if you wannna do it yourself get them dipped in a cold acid bath/paragon tank, sand them smooth with some wet and dry sand paper or if you have an angle grinder use that with a sanding wheel on it and then once its smooth and all the pitting is gone sand them with a really fine sand paper like 600 or 800 grit and then polish the sh!t out of them with some autosol and buffing wheel on the angle grinder
http://toyspeed.blakjak.net/profiles/profile.php?id=708
Horsepowers for bragging, Torques for dragging...
www.ology.co.nz
cr1mnl
Postby Bazda » Sun Apr 11, 2004 3:02 pm
it's not $20 a wheel!!!! $20 is do just the outer rim part if u got deep dish type mags.
Metro Hard chrome does full wheel polishing for something like $80-90 a mag.
Postby Fred » Mon Apr 12, 2004 4:58 pm
my bad ur right, was jst thinking about what i wanted to do, (the rims) dumdedoo
Fred
Postby AE85.6 » Mon Apr 12, 2004 8:33 pm
oh well might have a chat to the guys you mentioned anyways for a quick price otherwise ye might look at gettin stuck in
AE85.6
Postby ~KDL~ » Tue Apr 13, 2004 5:24 pm
Ace Metal Polishers Otahu
~KDL~
Users browsing this forum: Google [Bot] and 27 guests
