running in engoine after head gasket???
Postby Rollin' » Mon Apr 19, 2004 8:56 pm
just got a new headset on the rolla
do i need to run it in???
ive been told by sum people to run it in over 1000kms, but i cant help my self!!!
what will happen if i continue to do so?
AE82 16.4 @136kph
ex:AE80 dx sedan, the green machine
corrola's are for life:
not just for christmas!
http://toyspeed.blakjak.net/profiles/profile.php?id=166
Rollin'
Postby MrOizo » Mon Apr 19, 2004 9:04 pm
i think its rteally only important to watch oil, and water levels...
making sure you keep a close eye on them.
if you only have done a HG then it should be fine to give it a bit of WOT and revs.
MrOizo
Toyspeed Legend
Postby demis » Mon Apr 19, 2004 10:07 pm
give it some stick
EX 1984 Corolla FX GT (AE82) 1st gen 4age
EX 1996 Corolla BZ touring (AE101) 5th gen 4age -LSD
EX 1997 Carib Z touring (AE111) some 4afe muck
Ex 2000 Fielder S (ZZE122)- Its BIG RED
2002 Corolla Ts (ZZE122) Mr ~ Ts
demis
Postby M R 2 Mk1 » Tue Apr 20, 2004 9:16 am
just keep an eye on oil and water
dont thrash it to much till 1000k
Working Sucks and Thinking is for Losers
M R 2 Mk1
Postby Rollin' » Tue Apr 20, 2004 10:36 am
yeah, its getting a quick oil change at 2500kms.
i'll check the water, but it shouldn't go down anymore since it was leaking through the head gasket before, new thermostat too, i cant beleive how quickly it warms up!!
only reason i cant wait till 1000kms is that i live in the city, and i dont drive that far!!! well off to parlmy on saturday, so that will be my run in time,
AE82 16.4 @136kph
Rollin'
Postby M R 2 Mk1 » Tue Apr 20, 2004 1:24 pm
Just keep it under redline for extended periods of time and you'll be right :lol:
M R 2 Mk1
Postby evil_si » Tue Apr 20, 2004 10:38 pm
as long as its been done properly,
it will be sweet there is no reason to run it in as such,
it will either be sealed or not, if it blows theres something wrong
evil_si
Postby lost » Wed Apr 21, 2004 6:09 pm
the general rule is that for the 1st 1000km's you use plain water in the radiator, because coolant is thinner and it leaks thru the new seal preventing it from sealing. After 1000km's you just drain the system and chuck in coolant.
Octopus Thingy~!
lost
Postby Elmo » Wed Apr 21, 2004 6:22 pm
If new rings etc have been put in, then yes, its needs to be run in, but a new head gasket?? I dont think Ive ever heard of that, we certainly dont tell our customers that and the engines we work on go under much much more load than yours ever will.
Elmo
Postby Twolitre » Wed Apr 21, 2004 6:35 pm
I raced my old AW11 at taupo a few days after putting the engine back in after replacing all the gaskets on the engine inc head gasket, clutch etc and didn't have any probs with it for the next 5 months until I sold it.
Twolitre
Postby Rollin' » Wed Apr 21, 2004 7:04 pm
well that explains why there is isnt much coolant in the radiator. mainly water.
it should be sweet, better safe than sorry eh?
how much do a throttle position sensor go for second hand?? mine doesnt spring back.
AE82 16.4 @136kph
Rollin'
Postby Twolitre » Wed Apr 21, 2004 7:11 pm
Go to pick a part and pick yourself a throttle position sensor :D
Should have one there off a 4AG if not, then one off another toyota might work.
Twolitre
