Help!!! Engine Oid
Help!!! Engine Oid
Postby 4ageLova » Mon Apr 19, 2004 11:29 pm
Hello folks!
I just drained all used up engine oil and filled up with new oil.
Problem is, it was my first time and I wasn't sure how much to put in, so I put in 5L.
I checked the dip stick and the oil level is way over where it indicates "full."
So is it bad to put in too much oil?? Should I drain some??
For those using Blacktop 4age, how much do you guys put in to a completely drained crankcase??
'96 Trueno AE111
20v BlackTop
4ageLova
Postby Wind Rider » Tue Apr 20, 2004 12:00 am
hmm 5L should be alright bearing in mind your oil filter (if you've changed it) is empty. Take her out for a spin and check it again.
Wind Rider
Postby 4ageLova » Tue Apr 20, 2004 12:39 am
Wind Rider wrote:hmm 5L should be alright bearing in mind your oil filter (if you've changed it) is empty. Take her out for a spin and check it again.
I changed the oil filter, and I heard a gulping sound when I first turn the engine on after oil change. Maybe the sound of the filter taking some oil in.
Anyway, I just came back from test drive, and didn't find anything wrong.
So what happens if you put way too much oil anyway??
'96 Trueno AE111
20v BlackTop
4ageLova
Postby Wind Rider » Tue Apr 20, 2004 12:45 am
Having a tad too much oil shouldn't do any damage I don't think, and draining the right amount might be quite difficult anyway, you'll prolly end up draining half of it as soon as you loosen the plug enough for it to drain. You can of course pour some back in but I wouldn't recommend it unless you are using a brand new oil pan... A clean milk bottle might do the trick...
Just my 2 cents. :P
Wind Rider
Postby deaf_rattle » Tue Apr 20, 2004 1:16 am
is heaps
4age takes 3l to do an oil change.
not sure what motor you have
drain some before you damage your motor
Postby overkill » Tue Apr 20, 2004 2:32 am
it didnt feel at all sluggish?
and there were no plumes of smoke from the exhaust? like a demo jet at one of those airshows?
strange, coz ive seen this happen before. strange.
overkill
Postby celica_tommo » Tue Apr 20, 2004 2:39 am
my 2L 3S-GE takes right on 4L to fill... If it is cheapish oil I'd drain some of the excess but if it's more expensive and it seems to be going alright I'd leave it
celica_tommo
Postby M R 2 Mk1 » Tue Apr 20, 2004 9:15 am
dont leave it you'll $&#$% your engine
Working Sucks and Thinking is for Losers
M R 2 Mk1
Postby Ae92typeX » Tue Apr 20, 2004 10:07 am
Nah- thats way too much, drain some out or it will end up being a costly oil change for ya.
The blacktop 4age should take around 3.6l I think (including new filter).
It may not cause any damage, but it will cause extra pressure on all the seals and in the longterm be unhealthy 4 the engine.
Ae92typeX
Postby 96_Trueno_BZG » Tue Apr 20, 2004 2:17 pm
From the 4AGE repair manual
Drain And Refill
With Oil Filter change: 3L
Without Oil Filter change: 2.8L
Dry Fill: 3.5L
96_Trueno_BZG
Postby 4ageLova » Tue Apr 20, 2004 4:25 pm
96_Trueno_BZG wrote:From the 4AGE repair manual
Drain And Refill
Dry Fill: 3.5L
Thanks y'll
I'm gonna drain some oil when I get back home.
It's actually good that 4age takes only 3L 'cause it means less money for oil. So it will be about $55 per oil change including Toyota filter.
I put in Castrol R 5w-30. $55 for 5L at Repco. It was cheapish one of the Synthetics. It was my first time putting in Synthetic, and I think it drives much better than mineral.
I know it's good to change mineral oil every 5k, but I wonder how often I should change synthetic oil. Any suggestions
'96 Trueno AE111
20v BlackTop
4ageLova
Postby Mr Revhead » Tue Apr 20, 2004 5:25 pm
sheesh!
drain some now! thats waaaaaay to much!
Users browsing this forum: Bing [Bot], Google [Bot] and 15 guests
