1970 toyota corona
1970 toyota corona
Postby z|gen » Wed Apr 21, 2004 9:06 pm
hey guys
iv come across a 1970 toyota corona, but i havent been able to find out any specs for them, cept its a 1500 4spd manual,
does anyone have any info about these like chassis number etc or know where i could find some info..
thanx david
AE91 SUPERCHARGED COROLLA
z|gen
Postby liftback » Thu Apr 22, 2004 2:17 pm
chassis number/engine code can be found on the build plate on the firewall....
'95 Ce108 Mule
'98 Suzuki TL1000R
'98 Suzuki RG150E
Whats all this then?
liftback
Postby z|gen » Thu Apr 22, 2004 3:03 pm
im well aware of where it can be found, but im unable to view that as i dont own the carand the car isnt local,
kthx bye
z|gen
Postby Logan » Thu Apr 22, 2004 3:23 pm
Would either be a very late model (or late registered) rt40 corona with the 2r motor in it, or an early rt80 corona, which had 2r,4r,12r,18r's in them. Very cool cars, if the front is like my one its an rt40.
http://classic-celica.50megs.com/corona.html
Logan
SR Sold. Onto Other Things
Logan
Postby z|gen » Thu Apr 22, 2004 3:51 pm
yeah..it looks like that
what are their bodys like and performance etc ?
z|gen
Postby Logan » Thu Apr 22, 2004 7:56 pm
z|gen wrote:yeah..it looks like that
what are their bodys like <snip>?
What sorta question is that? look at the link to my site, or check out www.toyotacorona.com
performance is crap. due to its age lucky to get i dunno 2 hp outta it. but i think they are about 70ish standard, butbeg for a conversion, im in the process of 18rgeu transplant, well its all done just got to finish tiding up wiring and trim etc.
Logan
Postby z|gen » Thu Apr 22, 2004 9:30 pm
like rust wise etc..
do they rust in the same areas as the corollas ?
z|gen
i got 1
Postby sanchez » Fri Apr 23, 2004 12:08 pm
i got the 1970 rt80. mean as cars, quite rare. i got a 4age in mine, doesn't handle as well as the smaller toyota's (starlet, corolla etc) the only rust in mine is at the bottom of the front guard behind the wheel, doors and everything seem prettty mint.
sanchez
Postby Logan » Fri Apr 23, 2004 12:56 pm
Ditto on the rust, The two i have played with are both rusted at the bottem of the gaurds behind the wheel. Other bad spots are around the boot seal on any old toyota, they weather seal/strip has an unprotected metal spring system in the middle of the rubber, and this absolutly eats the lip that the seal clips over.
Other hot spots, include fluid leaks on firewall around master cylinders, battery acid leaks causing corrison around battery. Then usual bottem of doors, around the taillights....
Generaly if you look carefully in good light, you shoudlnt have a problem finding bad bits, which are good price negoitators...
Logan
Users browsing this forum: No registered users and 62 guests
