valve clearane
valve clearane
Postby phatman3801 » Fri Apr 23, 2004 10:18 am
hey i have a levin bzg, i started to notice a ticking noise when driving corrasponding to hte revs so i got it checked out and im told it is the valuve clearance on a couple of the valves and the shims will need 2 b replaced, it sounds like it wil be rather expensive to fix so is it doing ne harm jst leaving it? will it affect the performance of the car?? or is it jst annoying ticking noise i have 2 put up with and thats it?
phatman3801
Postby WeirdGTi16 » Fri Apr 23, 2004 4:13 pm
hey Phatman , shims not to bad to do and shouldn't be to expensive $5 -$15 each ? Can usually be done without removing anything major - ie only requires valve covers to be removed. But needs SST's (Special Service Tools)to do the job. Should only take about an hour or so ! Take it down to your local Toyota Dealer and get them give you a quote !
Mainly annoyance factor if just slight ticking but if left could develop into valve clearance problems which could effect your performance and reliability :!: :wink:
Never give yourself a haircut after 3 margaritas
WeirdGTi16
Postby 10k 20v » Fri Apr 23, 2004 9:57 pm
Umm, the 20 valve uses under bucket shims which means the cams will have to be removed. I doubt the noise is excessive valve clearance however.
I would be putting my money on the vvt pulley being a little rattly as thats a common fault.
10k 20v
Postby JRS » Sun Apr 25, 2004 4:51 pm
i agree entirely with the guy above me.
meh.....
JRS
Postby Mr Revhead » Mon Apr 26, 2004 3:25 pm
yeah they are valve under bucket style. if its the vvt pully then it wont be ticking. they make more of a knock or a slow rattle.
Postby 20v FX-GT » Mon Apr 26, 2004 4:14 pm
Most likely the VVT pulley but I haven't heard a noisy blacktop one yet - not one worth worrying about anyway. The noise normally disappears when VVT engages but you will need a VVT switch to test this.
1981 & 1982 MK1 VW Golf GTI 8v
1997 AE111 Toyota Trueno 6 Speed
My profile l AE101 FX GT Site l AE111 BZ Site l
20v FX-GT
Postby Mr Revhead » Mon Apr 26, 2004 4:28 pm
well it happens, iv sold a coupla new pullys for blacktops. but it not really a prob.... just annoying
Postby 20v FX-GT » Mon Apr 26, 2004 5:48 pm
Is the price the same for a blacktop and silvertop VVT pulley?
20v FX-GT
Postby WeirdGTi16 » Mon Apr 26, 2004 8:16 pm
hey yes sorry wasn't thinking 20v under bucket shims - doh
Hope you get it sorted :lol:
WeirdGTi16
Postby Mr Revhead » Tue Apr 27, 2004 11:42 am
no they are different
blacktop $476
silvertop $618
Postby 20v FX-GT » Tue Apr 27, 2004 12:00 pm
Thanks Mr Revhead.
20v FX-GT
Postby 10k 20v » Wed Apr 28, 2004 7:03 pm
the differnece between the blacktop vvt pulley from the silvertop is only the timing.
The only diff is 5 degrees lobe centre so if you can redrill the hole you could save $142
10k 20v
Re: valve clearane
Postby matt dunn » Fri Apr 30, 2004 7:12 pm
Does anyone know what the factory specs are for valve clearances on a silvertop?
I have been told 10 and 10 and also 14 and 17 but need some reliable info.
Matt
