. . . for a short distance to the work shop? prolly around 3-4km.
clint
RAZA wrote:i reckon you'll make it.
probably shouldn't but as long as you keep a good eye on the temp and take it as easy as possible you should be right.
oh and as long as your system is full of water if the pump is leaking at any rate then you shouldn't really even run it at idle
