Link ECU coldstart probs
Postby Jools » Wed Apr 28, 2004 1:05 pm
Anyone know why the Link ECU is causing me so much grief with cold startup? 1 out of 5 mornings it just wont turn over, and even when it does its a mission :evil:
Also anyone got any ideas on how to get a more stable idle from it?
90 Celica GTR Turbo
184kw @ 14psi at the front wheels (Now running 17psi watch this space for dyno :) )
"Owner of the fastest Celica GTR in NZ (Until proved otherwise ;) )"
www.Jools.tk
Jools
Postby Dell'Orto » Wed Apr 28, 2004 1:23 pm
Its apparently one of the problems they have with the earlier versions of Links...ought to have gone for a LinkPlus :wink:
You might be able to get newer software loaded on it, try giving them a call
Postby Jools » Wed Apr 28, 2004 2:06 pm
Yeah I think it is an early one...might try that
90 Celica GTR Turbo
www.Jools.tk
Jools
Postby 10k 20v » Wed Apr 28, 2004 7:25 pm
Also if you can, check the voltage at the link when cranking.
If it starts to drop to 11volts the link then reboots.
Been running link plus for a year now with no cold start probs.
10k 20v
Postby mister2 » Thu Apr 29, 2004 9:49 am
bah ahahahahahaah! sorry, but....
your engine wont actually crank? thats battery not the link. if it was cranking and not firing, well then id start looking at it.
if your batterys on the way out, they dont seem to like cold mornings. id check that first.
nick
www.nzefi.com
4WD Dynapack Dynamometer.
Link, MoTeC, Greddy, Power FC sales support and tuning.
Weapon of Choice: 1992 NSR250 SE
On hiatus, current location: Cambridge, UK
mister2
Postby 10k 20v » Thu Apr 29, 2004 7:48 pm
haha, your right, i didn't read closely enough.
A stable idle is acheivable, who tunes it?
10k 20v
Postby Jools » Fri Apr 30, 2004 1:08 am
Mix up of words...the engine cranks, but dosent fire.
Torque performance did the tuning.
I've been told theyre not the best tuners in the world, but he certainly did a good job in my eyes.
Its just that the idle tends to drop really low when you take your foot of, and tends to stall. Else it just goes low then works up to a proper idle
90 Celica GTR Turbo
www.Jools.tk
Jools
Postby mister2 » Fri Apr 30, 2004 11:24 am
hmm... thats a bit trickier.
yeah without idle speed control hooked up, its a bit more difficult to get a stable idle. generally i just wind mine up to about 900rpms by adjusting the throttle stop.
as for the not starting, check fuel and spark... but it might be 'crank enrich' not set high enough.
give link a call, they'll be able to set you right.
nick
www.nzefi.com
mister2
Postby fivebob » Fri Apr 30, 2004 12:09 pm
Not sure how it's done on the link but generally speaking to increase your idle speed/ get a stable idle then you advance the ignition over the idle speed range,and the advance should be the same for the whole idle speed range. On my Motec I set it the ignition curve flat below 1250rpms.
How much advance are you running at idle?
Postby Jools » Fri Apr 30, 2004 3:19 pm
No idea, dont have a hand controller unfortunately
90 Celica GTR Turbo
www.Jools.tk
Jools
Postby 10k 20v » Fri Apr 30, 2004 7:03 pm
it is possible the hot idle setting is not high enough which is probly why it starts off low then works it way up to the preset idle speed.
10k 20v
Users browsing this forum: No registered users and 60 guests
