Turning Back Odometer ?
Postby z|gen » Thu May 13, 2004 7:09 pm
hey guys
im gonna rebuild my engine, and i was thinking about also resetting the odometer to zero, it currently shows just over 600thousand kms, but the engine already had a rebuild before that, so how do i go about setting it back to zero so i know how much i will have done since i rebuilt the engine ?
cheers David
AE91 SUPERCHARGED COROLLA
z|gen
Re: Turning Back Odometer ?
Postby Twolitre » Thu May 13, 2004 7:21 pm
z|gen wrote:so how do i go about setting it back to zero so i know how much i will have done since i rebuilt the engine ?
By writing it down, rememberring it etc
It is highly illegal to rewind your odometer.
Twolitre
Postby z|gen » Thu May 13, 2004 7:33 pm
err..can i ask why it is highly illegal to turn it back ?:S
z|gen
Postby coleman » Thu May 13, 2004 7:36 pm
wouldnt it be faster to run it forward 400 thousand?
coleman
Postby Logan » Thu May 13, 2004 7:38 pm
drill on the speedo drive cable....
SR Sold. Onto Other Things
Logan
Postby AE85.6 » Thu May 13, 2004 7:38 pm
illegal to wind back no one said illegal to replace........... remove dash board replace with dash from newer car :D
If you drink, and drift,
your a bloody lunatic
AE85.6
Postby coleman » Thu May 13, 2004 7:39 pm
TOYODA wrote:wouldnt it be faster to run it forward 400 thousand?
also technically wouldnt be illegal
coleman
Postby Twolitre » Thu May 13, 2004 7:39 pm
z|gen wrote:err..can i ask why it is highly illegal to turn it back ?:S
Because it is essentially fraud, would you like to buy a car that had a lot more kilometers on the car than the odometer indicated?
Twolitre
Postby z|gen » Thu May 13, 2004 7:41 pm
err...but wouldnt it give a fairer indication of how many kms the engine has done..or would it still be fraud..?
z|gen
Postby matt dunn » Thu May 13, 2004 7:43 pm
Because it is law.
If you get caught doing it ( and you will as the readings are entered into the system each warrant ), you may face a big fine and even prison time in major cases.
That's why there's so much of a fuss about jap import speedo's being checked.
The public dont want to buy a new 199 toyota altezza with 36,000 kms only to find that it has actually done 360,000 !!!
Postby Twolitre » Thu May 13, 2004 7:49 pm
z|gen wrote:err...but wouldnt it give a fairer indication of how many kms the engine has done..or would it still be fraud..?
Yes, as far as the engine, but what about the chasis, the gearbox, the diff, the brakes, wheel bearings, interior, steering components, cooling system, prop shaft, electrical system etc?
Twolitre
Postby Adamal » Thu May 13, 2004 7:54 pm
Twolitre wrote:Yes, as far as the engine, but what about the chasis, the gearbox, the diff, the brakes, wheel bearings, interior, steering components, cooling system, prop shaft, electrical system etc?
Don't you hate it when you have some input to a thread as you're halfway down, and when you get to the end, you find someone has beat you to it???? :P
Postby Twolitre » Thu May 13, 2004 8:07 pm
Adamal wrote:Don't you hate it when you have some input to a thread as you're halfway down, and when you get to the end, you find someone has beat you to it???? :P
hahah yup :wink:
you win some you loose some I guess lol
Twolitre
Postby EVLGTZ » Thu May 13, 2004 10:11 pm
drive in reverse from now on :lol:
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby M R 2 Mk1 » Thu May 13, 2004 10:16 pm
you can but you gave to go to the post office and register it with that amount of kilometres on the clock
Working Sucks and Thinking is for Losers
M R 2 Mk1
Postby Ae92typeX » Fri May 14, 2004 12:23 am
When I rebuilt one of my minis from the ground up (literally everything) I set the odo to 0. Would have been obvious at wof but I never got in trouble or mentioned.
In saying this when I sold it I didnt try and say it had been in a gaurage for 25years...
Ae92typeX
Postby Ae92typeX » Fri May 14, 2004 12:24 am
Oh- I took the speedo fully apart when I did it
Ae92typeX
Postby ~SlideWays~ » Fri May 14, 2004 12:35 am
and it would look weird when you get the previous owners details after changing ownership and find the the km's drop to nothing when it gets to your name :lol:
~SlideWays~
Postby Ae92typeX » Fri May 14, 2004 12:44 am
now that I think about it, the mini had one less diget...thats probably why I didnt have much hassle...guess they wernt ment to last that long lol
Ae92typeX
Postby Logan » Fri May 14, 2004 12:22 pm
same with the old toyotas, they only have a 5 digit, hence only up to 99,999 k's not as bigga drama
I have a "friend" with a "modified ke25" which is getting a hybrid 3tgteu built for it, it current sits at 95,xxxx, whats another 5000 in 3 months of build time :wink:
Logan
Logan
