Hmm hows about 15psi on std 4age and 25psi on stad 4agze, as long as tuning and fuel are good then this can be done without too much of a problem at all
Drifter4ag wrote:uhh ..we dont get knocking at 15 or 25psi ... and most add on turbo kits arent designed to 4age as pretty much every man and his dog drives sometihng else.
Most custom made kits when sold from performance shops ive spoken to are tuned to run around 12psi on stock compression engines .. later model hondas have problems with this because they are around 11:1 compression ratio and are limited to under 10psi or bang bang ...
but.. as ive said before ..you can do pretty much anything with aftermarket ecu
in stock terms, 20 v wins.
Quote:
all you need to do to a 16v red top his get your self a decent set of extractors made and change the cam timing. Does anyone know Ted Javis he has raced a corolla fxgt ae92 with red top for many many years now they even qualified for bathurst one year and they raced at bathurst with a pretty standard engine. He said he makes 145hp at the fly wheel in a light rolla so it honks pretty good. But yea next step would be cams but the class he is in they arent allowed to change cams.
Stock 20v already make that.
I made near on 165hp flywheel with just cams on my 20v
Going back on sat to see where i am now. Hoping close to 180 now
