PHAT|GTZ wrote:far out, does it cost $1200 for new rings and new bearings? pretty crazy!!
mike86ze wrote:let your fingers do the walking man
johnsons piston rings would be a good start.
if you torque everything back up to spec it shouldn't matter if they have or haven't stretched.
matt dunn wrote:If you remove the rods fromit you will have to replace the rod bolts as well or eventually it will toss a rod as they stretch and come undone.
Have seen it happen on a few engines now.
as far as the bolts go toyota use 'torque to yeild' bolts on things like head bolts, rod bolts and main caps. (but not for every engine) best to use new ones as they are a lot cheaper than a new engine!
Users browsing this forum: No registered users and 42 guests
