The old "warming up the oil' question
Postby Sanxta » Sun May 16, 2004 5:27 pm
(From cold) Some say it's best to leave the car idling to warm up you oil, others say it's best to drive it at low revs to get the oil circulating and warmed up faster than idle does.
What is the least-damaging way to warm the car up? Wait or drive?
Chur
Sanxta
Postby Farmer_dave » Sun May 16, 2004 6:16 pm
Im guessing leaving it to idle would be best but it does take a while and if your like me you dont want to start your car and wait for it to warm up in some situations its possible but not others so I usually let it idle for a minute and just drive at low revs till it reaches a warm temp.
My Profile:
Now updated with a new pic
http://toyspeed.blakjak.net/profiles/profile.php?id=201
1997 Caldina GT-T
Farmer_dave
Postby bridgeport » Sun May 16, 2004 6:18 pm
not good for valve seats leaving a car idle for ages
bridgeport
Postby Al » Sun May 16, 2004 6:40 pm
I think general rule of thumb is let it idle for a minute or two then drive at low revs. The quicker you get your car up to operating temp and oil circulating, while driving like a nanna the better.
Al
Postby Farmer_dave » Sun May 16, 2004 8:52 pm
The main problem with my GT-T is that its an auto and it wont change into 4th until it reaches normal operating temperature so you have to sit at about 70-80 k's or rev the shit out of it until it changes which is rather annoying to say the least :x
My Profile:
1997 Caldina GT-T
Farmer_dave
Postby Chickenman » Sun May 16, 2004 10:02 pm
Me........ Jump in at 4:59 Start the bitch, Idle 30 seconds, reverse and turn around, On to deserted road, cane the snot out of it :D
I think it warms up so quickly cos there's no oil in it neway, that shit is overrated.
:wink:
Baby Jesus
Chickenman
I Am The Walrus!
Postby Twolitre » Sun May 16, 2004 10:05 pm
What AL said
Twolitre
Postby deaf_rattle » Sun May 16, 2004 10:14 pm
i agree with al and ryan on this one.
although with the 5m its more like start let it die and then start again and out the driveway i go.
when the new engine goes in ill probably give it abit more respect however.
Postby www.mods.co.nz » Mon May 17, 2004 2:03 pm
The best way to make sure your not damaging your engine is to put an oil additive in with your quality oil.
I have used PRO-MA MBL8 oil additive in my cars for the past 9 years and I think the additive is brilliant.
It extends component life and maximizes protection.
Can reduce heat and wear, providing superior lubrication and total component protection.
Features:
Can increase HP and fuel economy
can restore compression
can reduce exhaust emissions
can reduce wear and tear
can reduce downtime and maintenance
can save money in running costs
Let me know if you want some @ $29.90 per 250ml bottle you will get 3 oil changes out of one bottle just under $10 per oil change
021 986 322
MODS Performance Car Parts Limited
Email: andre@mods.co.nz
Web Site: www.mods.co.nz
Mobile: 021 986 322
www.mods.co.nz
Postby Loudtoy » Mon May 17, 2004 8:08 pm
www.mods.co.nz wrote:The best way to make sure your not damaging your engine is to put an oil additive in with your quality oil.
Features:
021 986 322
Sounds like an add to me :lol: But a quick quesiton to you - can you please explain to me how an oil additive can restore compression?? Not disbelieving you - yet - just plenty curious.
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Postby Adamal » Mon May 17, 2004 8:27 pm
Well IIIIII duuuunnoooooooo...
You see www.mods.co.nz, I'm a really skeptical person from WAY back!
How can you prove to me that this stuff will help me go that extra mile???
</cheesey infomercial "disbeliever">
Postby Farmer_dave » Mon May 17, 2004 8:47 pm
I like to use Mobil one and wouldnt like adding some additive it thats just the way i feel anyway.
My Profile:
1997 Caldina GT-T
Farmer_dave
Postby fivebob » Mon May 17, 2004 8:55 pm
www.mods.co.nz wrote:A whole lot of unsubstantiated crap about the snake oil he sells
Don't do it, the additive package in modern oils is all you need, this snake oil crap is just a waste of money, and probably harmful to your engine.
Postby Farmer_dave » Mon May 17, 2004 8:58 pm
What oil do you recomend for the gt-t Five??
My Profile:
1997 Caldina GT-T
Farmer_dave
Postby Twolitre » Mon May 17, 2004 9:06 pm
PRO-MA MBL8 is not a mechanic in a can but if you have a car with noisy hyraulic lifters such as a subaru/mitsi etc it is about the best thing you can get, many people on NZMMC use it in their high HP engines.
Twolitre
Postby Simon K » Mon May 17, 2004 9:30 pm
A lot of the guys on MMC use MBL8 to quieten their lifters...others just change their oil at regular intervals.
I don't use it, others do and swear by it.
Simon K
TS Wannabe
Postby fivebob » Mon May 17, 2004 9:34 pm
I use Mobil -1 but any good synthetic oil should be ok, even a good dino oil if it's changed at shorter intervals
Now back to the topic.
You shouldn't idle your car for longer than it takes to get the oil pressure up and the idle to stabilise, at most this should be about 30secs. The only time you should leave it idling longer is when you need to defog the windscreen.
Idling your engine for extended periods on warmup is bad. The longer it takes the car exceed the boiling point for the combustion byproducts, the more particulate formation. This leads to sludge, varnish and particulates in your oil. Also to the wear this contamination causes, and you need to change your engine oil more frequently because you reach the oil's particulate threshold quicker.
As well as particulate formation you also get increased acids in the engine oil, but because the temp is lower they are are not boiled off quickly and you get corrosion of the engine metals.
Idling for long periods isn't the only cause of such problems, you can get the same issues by taking lots of short trips because it takes time to boil off all the byproducts. If you do not allow the engine to rid itself of these byproducts (about 10-15kms of open road driving) then they will contaminate your oil and cause excessive wear on your engine. Which is why a car driven in the country usually has a better condition engine than on driven on short trips in the city.
Re: The old "warming up the oil' question
Postby matt dunn » Tue May 18, 2004 12:17 am
Sanxta wrote:(From cold) Some say it's best to leave the car idling to warm up you oil, others say it's best to drive it at low revs to get the oil circulating and warmed up faster than idle does.
Chur
Ever driven a car with an accurate oil temp gauge?
You dont realise how much longer it takes to warm up the oil than the water!
I dont believe that letting the car idle for 3 minutes from dead cold would change the oil temp up by even 10 degree's!!!
So whats the point. As long as the gets oil pressure before you drive it will be ok.
The only problem yopu can have is excessive oil pressure whenj cold if you rev it to much.
