will it be difficult to put a blue top head on a rwd 3a
Postby Peradx » Mon May 17, 2004 8:36 pm
Instead of going the hole hog and putting a 4age into my ae85 I`ve decided to put a blue top 4age head onto the 3a block. I`ve brought the loom and computer so far.
What else am i going to need apart from the head.
What problems could i face doing this?
Peradx
Postby ee904age » Mon May 17, 2004 11:52 pm
im not sure if it will fit, but if it does you are going to need fuel pump, lines and rwd manifolds aswell. Theres probably more but im tired and can think. :roll:
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
hahahaha
Postby M R 2 Mk1 » Tue May 18, 2004 3:22 am
Peradx wrote:What problems could i face doing this?
Every problem under the sun
Working Sucks and Thinking is for Losers
M R 2 Mk1
Postby nzae86 » Tue May 18, 2004 9:00 am
It would be easier to phone around all the Toyota dealers and find a NZ new ae86 that is still brand new and buy that!
nzae86
Postby Ae92typeX » Tue May 18, 2004 9:27 am
Assuming none of the oil galleries etc wernt made larger for the 4age etc it should be doable.
Why not run it on carb's thou?- less hassle (sortov) than wireing up ecu and then ya get that beaut sound too!
Ae92typeX
Postby nzae86 » Tue May 18, 2004 10:48 am
Think about the crank and how are you going to drive the cam belt, valve to piston clearance , water jackets , oil feeds, etc, if you did get it to go it wouldn't be long before you had a rod out the side and then at the end of the day why? a 1500 cc twin cam ?
nzae86
Postby spencer » Tue May 18, 2004 11:02 am
botom end on 4ag resonably light, I imagine 3a is not as good also incorrect fly cuts on pistons probly, dam how much is a blue top worth these days naff all just the rwd bits are expensive. I think it would be way more trouble than its worth.
ms63 crown
spencer
Postby liftback » Wed May 19, 2004 7:16 pm
2a-ge has been done by someone of club-k (thats a 1300 twin cam), didnt really have any trouble i believe, just bolted on as if it were the 4a block.... apparently revved alot harder too...
'95 Ce108 Mule
'98 Suzuki TL1000R
'98 Suzuki RG150E
Whats all this then?
liftback
Postby bridgeport » Wed May 19, 2004 9:36 pm
i have a block and head blocks a 7 rib heads a tvis i think
$100 and its urs pm me if ya keen
bridgeport
Postby Peradx » Thu May 20, 2004 11:45 am
hey thanks man, thou I`ve been given a red top head yesterday with mild cams for free. also been offered a intake manifold for $200. (is that an ok price? its a spare 1 off his race car)
where a bouts are you?
Peradx
Postby bridgeport » Thu May 20, 2004 1:49 pm
free is a good price to pay for that head lol as for the intake manifold im not sure but for that price ya want a throttle body reason there worth a bit is cause everyone uses them for 4agze conversions (i think)
theres one here in aucks for $20 but i dunno if its still there
im in auckland
bridgeport
Postby spencer » Thu May 20, 2004 6:17 pm
$200 is probly a fair price, the reason a factory rwd 4age intake manifold is rare/expensive cos every time sum one puts a 4age in a dx or a 30 or sumthin you need to buy a buy/make a manifold to suit i guess
ms63 crown
spencer
Postby matt dunn » Fri May 21, 2004 12:31 am
ke70wagon20v wrote:$200 is probly a fair price, the reason a factory rwd 4age intake manifold is rare/expensive cos every time sum one puts a 4age in a dx or a 30 or sumthin you need to buy a buy/make a manifold to suit i guess
Except that if it's a proper rwd manifold it wont fit his head and if it's a fwd it's overpriced
Postby skoty » Fri May 21, 2004 11:30 am
Remember as both engines (3a and 4age) are both 'A' series engines everything should be interchangable and Ive seen it being done before, however minor modifications may be necessary. I was thinking of building a 2age at one stage (2a block with 4age head) for a 1300cc restricted race class.
skoty
Postby Drifter4ag » Fri May 21, 2004 1:58 pm
want good motor ? here it is
3au engine
bluetop crankshaft so you can use the 8bolt flywheel series. Other than that i dont see why the head wont go on ok and belts be fine as its only cyl size difference not stroke. If you run into problems with flycuts on pistons .. you could have a look at a 5afe engine which is 1500 twincam and pistons from that or complete bottom end could suit.
Garage |-" '|
Current Rides
AE86 Notchy (Finally through compliance after 5 years)
Vitz RS :D
Previous,
1x SXE10 Altezza, 2xAE111 Caribs, 3xKP60, 2xke35 SR Coupes, 2xAE85s, 2xAE86 Road Car, 1xAE86 Drift Car 182kw@wheels, 1xJZZ30 Drift Car 360ps
Panspeed Special 450ps Drift Car
JZX91 MARK II CHASER
JZX81 MARK II CHASER..... so many more that i forgot....
Drifter4ag
Postby MetalupYoAss » Sat May 22, 2004 1:23 pm
yeah, id say its possible... like putting 2K head on a 4K but much more complex.. probably easier at the end of the day to just drop a 4age straight in but 3age would be more styley :P
MetalupYoAss
Users browsing this forum: Bing [Bot] and 13 guests
