AE82 help
AE82 help
Postby skathed » Sun May 09, 2004 7:13 pm
will a 4agze fit in a ae82 rolla?
skathed
Postby ChaosAD » Sun May 09, 2004 7:30 pm
Absolutly, but the supercharged gearbox needs a few mods done the the x-member to fit in.
Do a search, should be quite a bit about it in old posts.
Also do a search at http://www.twincam.org/forums
ChaosAD
Postby skathed » Sun May 09, 2004 7:48 pm
thanx, so it will drop right in?
skathed
Postby evil_si » Sun May 09, 2004 8:06 pm
yes
evil_si
Postby ChaosAD » Mon May 10, 2004 8:13 pm
The engine istelf will drop straight in, but to use the factory c52 gearbox you will have to put your old flywheel on it as the 4agze flywheel wont fit in the bellhousing. youll also need the ecu/loom and youll have to splice the looms together. youll have to cut a hole in your bonnet and put in a scoop or ditch the a/c and install a front mount.
The gearbox probably wont last long if you drive it hard though (and who would transplant a gze and just nanna it)
ChaosAD
Postby Helious » Tue May 11, 2004 3:15 am
Yeah, it'll fit
I have an AE-82 FXGT with a 4AG-ZE + LSD Gearbox from an AE-92 Levin GTZ :)
goes nuts....
Getting FMIC + 12/14psi pulley soon
I'm sure i'll die soon after :p
Helious
Postby bridgeport » Tue May 11, 2004 9:50 am
anonther engine i was thinking of was a 4efte ? the gt starlet engine because its already turbo and theres heaps of aftermarket bolt on goodies for them
my fxgt gearbox took years of skids and abuse poped a set of 205,14"s
but youd want to upgrade to an lsd
bridgeport
Postby skathed » Tue May 11, 2004 6:53 pm
4efte?
ughhhhhh....
skathed
Postby overkill » Tue May 11, 2004 10:57 pm
1300 12v dohc turbo
from ep82 gt starlets
and glanza v's
overkill
Postby skathed » Wed May 12, 2004 7:24 pm
how much would on of thoes go for?
ughhhhhh....
skathed
Postby liftback » Fri May 14, 2004 1:51 pm
Helious wrote:Yeah, it'll fit
goes nuts....
What did you have to do as far as getting the LSD box in? What did it set you back cost wise?
'95 Ce108 Mule
'98 Suzuki TL1000R
'98 Suzuki RG150E
Whats all this then?
liftback
Postby SIDE_FX » Tue May 18, 2004 4:04 pm
the starlet engine bolts straight in if u have a 2e motor in me and my mate are doing this to his car as we speak
SIDE_FX
Postby Mr Revhead » Tue May 18, 2004 4:07 pm
iv got an ae101 gze box with lsd and shafts for sale....
Postby liftback » Tue May 18, 2004 4:29 pm
Mr Revhead wrote:iv got an ae101 gze box with lsd and shafts for sale....
I would take you up on it too, cept i dont have any money at all :P
'95 Ce108 Mule
'98 Suzuki TL1000R
'98 Suzuki RG150E
liftback
Users browsing this forum: Google [Bot] and 27 guests
