how do I increace bluetop compression ratio to 10.5:1?
Postby ChaosAD » Wed May 19, 2004 7:03 pm
I have a standard bluetop bottem end and head. I also have a trd 0.8mm head gasket.
Does anyone know what volume the combustion chambers need to be in order to get a CR of 10.5:1?
Id also like to know the swept volume and the volume between the pistons and the deck of the block if anyone knows them.
Thanks,
ChaosAD
Re: how do I increace bluetop compression ratio to 10.5:1?
Postby matt dunn » Thu May 20, 2004 1:27 am
37.7cc
if the engine you have now is 8.5:1 then it will have combustion chamber of 46.67 cc
so you will need to remove about 9 cc of space
1587 cc
Postby ChaosAD » Thu May 20, 2004 8:17 am
does that combustion chamber volume include the head gasket and the tops of the pistons? or is it just the head?
ChaosAD
Postby mister2 » Thu May 20, 2004 10:32 am
theres a thread about 10 below this which gives the math to work it out...
*edit* sorry thats such a f*cking useless comment by me *edit*
nick
www.nzefi.com
4WD Dynapack Dynamometer.
Link, MoTeC, Greddy, Power FC sales support and tuning.
Weapon of Choice: 1992 NSR250 SE
On hiatus, current location: Cambridge, UK
mister2
Postby matt dunn » Thu May 20, 2004 8:50 pm
ChaosAD wrote:does that combustion chamber volume include the head gasket and the tops of the pistons? or is it just the head?
thats just a math calculation from the swept volume so it will include the gasket head and everything.
Postby Drifter4ag » Fri May 21, 2004 2:01 pm
or for a rough estimate according to lyn rogers .1 off head/block/gasket = .1 up on compression ratio ... soooo
say bluetop has 9.4 .. stock bluetop headgasket is 1.0mm and redtop is 1.2mm .. run a .8mm gasket on bluetop and you are up at 9.6 and on redtop you are up at 10.7
Garage |-" '|
Current Rides
AE86 Notchy (Finally through compliance after 5 years)
Vitz RS :D
Previous,
1x SXE10 Altezza, 2xAE111 Caribs, 3xKP60, 2xke35 SR Coupes, 2xAE85s, 2xAE86 Road Car, 1xAE86 Drift Car 182kw@wheels, 1xJZZ30 Drift Car 360ps
Panspeed Special 450ps Drift Car
JZX91 MARK II CHASER
JZX81 MARK II CHASER..... so many more that i forgot....
Drifter4ag
Postby ChaosAD » Fri May 21, 2004 7:33 pm
Oh, is the stock bluetop headgasket only 1mm?
ChaosAD
Postby Drifter4ag » Tue May 25, 2004 3:06 pm
according to our special gasket man yes ..1mm and 1.2 for redtop/4agze
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
Drifter4ag
Postby Rollin' » Tue May 25, 2004 8:16 pm
i shaved off .5mm of mine, was told it would raise a couple of points, from 9.4:1 to 9.6-7:1.
so if .5mm raises it .25 points, to get to 10.5:1 thats a reduction of 2.125mm.
and im sure i measured my old headgasket at 1.2mm
AE82 16.4 @136kph
ex:AE80 dx sedan, the green machine
corrola's are for life:
not just for christmas!
http://toyspeed.blakjak.net/profiles/profile.php?id=166
Rollin'
Postby ChaosAD » Tue May 25, 2004 10:13 pm
Drifter4ag wrote:or for a rough estimate according to lyn rogers .1 off head/block/gasket = .1 up on compression ratio ... soooo
I dont see how that would work, cos the cross sectional area of the combustion chamber in the head is less than that of the head gasket/block because of the squish bands.
Therefore removing 0.1mm off the block or head gasket will be will remove more volume than the taking 0.1mm off the head. :?
ChaosAD
Postby Drifter4ag » Wed May 26, 2004 12:38 pm
forget that the headgasket size is blabla its what it compresses down to after its on that you worry about .. and im just repeating what lyn rogers told me as a rough estimate .. .1 off head = .1 up in compression ratio
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
Drifter4ag
Postby TRDWGN » Wed May 26, 2004 6:40 pm
:lol: And if anyone knows you can be sure Lyn Rogers knows! He's be making cars fast since before most people on here were conceived!!
TRDWGN
