Do All Altezza's have LSD??
Postby matt dunn » Wed May 26, 2004 12:18 am
Postby voiceinsideyou » Wed May 26, 2004 12:52 am
No.
Of the RS200s, only the Z-edition and L-edition 6-speed manual models have the LSD as standard, and it's available as an option on the autos.
However, on the slower AS200s, it is standard on all manual models, as far as I know (not just Zs and Ls). It's not available on the auto AS200s.
voiceinsideyou
Postby 20v FX-GT » Wed May 26, 2004 8:56 am
What is better? The Z or the L edition? What are the differences?
1981 & 1982 MK1 VW Golf GTI 8v
1997 AE111 Toyota Trueno 6 Speed
My profile l AE101 FX GT Site l AE111 BZ Site l
20v FX-GT
Postby voiceinsideyou » Wed May 26, 2004 10:08 am
Technically, the L-edition, but firstly, I've never seen one, and secondly, most of the L-edition "extras" are available on the Z-editions.
From an engine/suspension/drivetrain perspective, they're the same as far as I know, and the way to pick one from the other is seat material - leather=L edition, regular black fabric=Z edition. The L-edition also has a powered front seat. :p
If you want more information have a read of:
http://www.japanvehicles.com/newcars/to ... a/main.htm
and in particular, the RS200 equipment list at:
http://www.japanvehicles.com/newcars/to ... pRS200.htm
Makes it easy to spot Z-editions as well. :-p (because most people don't even know they have a Z-edition!)
voiceinsideyou
Postby AXNGRL » Wed May 26, 2004 5:10 pm
on the z edition, you either got an lsd or traction control...
AXNGRL
Postby voiceinsideyou » Wed May 26, 2004 5:20 pm
What do you mean, AXNGRL?
The 215hp Z and L edition RS200s have both the Torsion LSD and Traction Control as standard on the manuals. Both of them are options on the autos.
You might be thinking of the 153hp AS200s, where on the manual the LSD was standard, but TRC optional, and on the auto there's no LSD, but TRC is still an option.
voiceinsideyou
Postby qik20v » Wed May 26, 2004 5:39 pm
what do lexus is200's have then? are they just a 'L' edition with new badges everywhere
1996 AE111 Toyota Levin BZ-G - 15.1 @ 146km
http://toyspeed.blakjak.net/profiles/profile.php?id=301
qik20v
Postby voiceinsideyou » Wed May 26, 2004 6:40 pm
I think they're roughly equivalent to an L-edition AS200 (note, not RS200), but I could be wrong.
In fact, I could be wrong on all of this. :-] (standard disclaimer)
voiceinsideyou
Postby AXNGRL » Thu May 27, 2004 1:49 pm
voiceinsideyou wrote:What do you mean, AXNGRL?
my partner (squid off Lexus Owners Club) has a 6spd manual altezza & it certainly does not have an lsd. We were told that it was either one or the other on those cars.
AXNGRL
Postby voiceinsideyou » Fri May 28, 2004 9:55 am
Perhaps it was different for the 98 Altezzas to 99 and on then? If you check around, there is certainly lots of places having reference to the Altezzas having LSD as well as traction control.
voiceinsideyou
Postby voiceinsideyou » Fri May 28, 2004 10:03 am
Hah - even the Altezza experts are arguing about this now - hah!
Have a read on:
http://nz.lexusownersclub.com/forums/in ... c=761&st=0
for a discussion on the LSDs... :-]
voiceinsideyou
Postby AXNGRL » Fri May 28, 2004 10:08 am
gee, now look what you've started ;) :D
AXNGRL
Postby anthonym » Fri May 28, 2004 12:29 pm
I translated the Toyota Japan spec sheet back in 2000 and the RS200Z 6 speed definitely listed a Torsen LSD as standard, it was an option in the auto, as was TRC. Don't know about the L. I never actually verified the physical presense of an LSD on my RS200Z before I sold it, but my AS300 Gita definitely has one :wink:.
anthonym
Postby Shotgun » Fri May 28, 2004 1:32 pm
What series diff are they?
Shotgun
Postby Squid » Fri May 28, 2004 5:18 pm
Shotgun wrote:What series diff are they?
Specs:
Model M/T F19TX
Differential Gear Ratio: 4.100
Ring Gear No. Teeth – 41
Size – 190mm
Drive Pinion No. Teeth – 10
Number of differential pinion – 8
Oil SAE90 API GL-5
Squid
Postby voiceinsideyou » Fri May 28, 2004 7:40 pm
Okay, looks like my information was right after all! Cheers for that Squid - very useful.
voiceinsideyou
Postby Al » Sun May 30, 2004 6:45 pm
http://english.auto.vl.ru/catalog/toyot ... a/1998_10/
AS200 : No LSD and TCS was option
AS200 Z ed : same as AS200
RS200 : both LSD and TCS standard
RS200 Z : same as RS200
If you dont have a real lsd (read: Helical or clutch pack) it wont spin the wheels the same way if you jack it up and spin them.
Al
Postby voiceinsideyou » Sun May 30, 2004 7:29 pm
That site simplifies it as the options were different on manuals versus autos. I presume it is referring to the manual versions.
voiceinsideyou
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 3 guests
