boot leaking
boot leaking
Postby RandomTask » Sun May 30, 2004 5:02 pm
a mate took my boot seal(kp61 starlet) off today to inspect for rust... and i noticed later that day when it started raining that it was leaking quite badly... from inside it looks like its leaking from between the rubber seal and the metal lip it slots on to... ive never noticed it leaking before.
is it possible or probable that in taking the seal off my friend might have buggered it somehow? if so where can i get a new seal from? is there meant to be some adhesive between the seal and the metal lip?
all help appreciated :)
RandomTask
Postby Ae92typeX » Sun May 30, 2004 8:14 pm
I'd be pretty surprised if it was leaking through there. More likely when you guys put it back on you put it at a slightly different position than before and being old the rubber has moulded in the boot shape, hence there may be a low area/gap.
Ae92typeX
Postby RandomTask » Sun May 30, 2004 8:33 pm
oh yep... either way a new boot seal would fix it aye?
thanks :D
RandomTask
Postby Ae92typeX » Mon May 31, 2004 9:55 am
yep, new seal should make it better than its ever been. Im not to sure where to get one thou sorry
Ae92typeX
Postby scotts2hot » Mon May 31, 2004 11:05 pm
Try putting vaseline on the seal, it should soften the rubber so you get a better seal.
scotts2hot
Users browsing this forum: No registered users and 67 guests
