Busted slave cylinder
Postby Shotgun » Wed Jun 02, 2004 7:35 pm
Was bleeding up a brand new slave cylinder and it started pissing fluid out front rubber boot of the actuator.
There's no way I could have caused this right? Just a case of a faulty seals? Just checking before I go throw my weight around at BNT.
Shotgun
Postby M R 2 Mk1 » Wed Jun 02, 2004 9:09 pm
sounds like seals to me
BNT are scarily unknowledgable about brakes and clutches, it took me three goes of trying to buy brake lines for my series 1 seven before I said $&#$% and went to autopoint
Working Sucks and Thinking is for Losers
M R 2 Mk1
Postby Monsterbishi » Wed Jun 02, 2004 9:35 pm
Yeah, sounds like a faulty seal, although might pay to check there is even one in there, had a mate who bought a cylinder that didn't even have one...
Needless to say it leaked...
--- Cut Here ---
'94 JDM Ford Mustang GT Coupe
Monsterbishi
Postby Shotgun » Thu Jun 03, 2004 12:16 am
Thanks for your advice. Not to go on a BNT hate spree but they had incorrect listings for lots of the JZA80 clutch parts I enquired about aswell. Wrong sizes etc.
Hrmm I'll go and see them tomorrow and try to scam some free fluid from them.
Shotgun
Postby bridgeport » Thu Jun 03, 2004 2:28 am
just a warning ive said x companys no good on here before to try help someone out and few weeks later got a lawers letter saying its defimation of their name cort blah blah just a heads up
bridgeport
Postby M R 2 Mk1 » Thu Jun 03, 2004 9:29 am
If I had bad mouthed them then I would have a concern, But im not, im simply stating my personal experiences with the shop in question
M R 2 Mk1
Postby deaf_rattle » Thu Jun 03, 2004 9:29 am
im sure what alan has said wouldnt get him in any trouble with the law.
a professional outfit like bnt should be getting simple things like part listings/numbers right.
talking about companies that are crap, FREEFLOW still suck big floppy donkey dick.
Postby Twolitre » Thu Jun 03, 2004 9:34 am
bridgeport, may I ask how they got your address ??
Twolitre
Postby Shotgun » Fri Jun 04, 2004 2:18 am
Anyway... got my replacement slave. Bled it up. Pissing fluid out boot again. Before you ask, yes I've performed this task successfully before.
Can somebody confirm whether there's any possible way I could screw this up?
Shotgun
Postby bridgeport » Fri Jun 04, 2004 9:22 am
dunno how they knew where i lived mabey to do with my old job ?
we used to go in there all the time
bridgeport
Postby Shotgun » Fri Jun 04, 2004 2:45 pm
Shotgun
Postby AE25 » Fri Jun 04, 2004 7:30 pm
did the piston fall out at any stage? i've had one pop out before when the clutch fork is not holding it in... mine had a return spring behind it and nothing really holding it in so when the clutch fork was taken off the piston popped out and the rubber boot fell off too coz it was old and oil soaked. if you were to push it back in and the seal got damaged then yeah it could be you :roll: they should have a circlip or something holding em in tho so not sure if this is any help. im talkin bout T50 or W5# box slaves here.
E2 & E7 fanatic
'71 ke26 '75 KE25 SR 4AGE '78 bug KP60 '83 KE70 SR Coupe 3TGTE '84 ke74 '84 ae85.6 trueno '84 YN57 SR5 '86 AE82 FXGT 20v '91 ST185 '92 SW20
http://www.toycrazy.net
AE25
Postby Monsterbishi » Fri Jun 04, 2004 7:32 pm
Shotgun wrote:Anyway... got my replacement slave. Bled it up. Pissing fluid out boot again. Before you ask, yes I've performed this task successfully before.
You do have the slave pushrod in there and it's the right length?
--- Cut Here ---
Monsterbishi
Postby Shotgun » Fri Jun 04, 2004 10:01 pm
It was me. :roll: Piston was going ever so slightly past its 'point of no return' and busting seals. They turned out to be far more short-stroke than I anticipated. :D
I'll let this thread die to hide my incompetence. :D
Shotgun
Users browsing this forum: No registered users and 26 guests
