Mr Revhead wrote:hehe welcome to MR2s they have a computer running the steering in those.. also a driver box and an electric pump, nice things to replace. a
mate has one that does some thing simalar... if it idles too long the light will come on and the steering will become heavy, rectifys itself once ignition is turned off then on. this has been diagnosed as the valve in the pump on his one, also the pump is a very popular item 2nd hand so it may be that the majority of failures are the pump. we have had a few in here that needed the driver box replaced.
dirtry relay contacts are the cause of 99% of problems with MR2 power steering, switching the ignition 20 or so times generally cures it
The relay can be replaced by an external HD item if it finally fails
could have been a miss comunication there.....
The reason for the popularity of the secondhand pump is that the speedway guys use them to put power steering in their cars, not a reliability issue at all
thats a good idea, ill look at doing that on my mates one, well sugesting it anyway.. no way im mucking with the electrics![]()
that sounds logical but there are a lot of wreckers that are after them to fix the steering problems common in the sw20, sounds like they maybe after the wrong bit then...
