Can you disable the 4AGZE knock sensor?
Postby Monsterbishi » Tue Jun 08, 2004 4:05 pm
Without the ecu pulling the timing?
Need to suss this out, since the NA block we're using doesn't have the hole drilled for the sensor, and it's gonna be a cold day in hell before I pull it all apart just to drill and tap one hole ;-)
--- Cut Here ---
'94 JDM Ford Mustang GT Coupe
Monsterbishi
Postby Stu- » Tue Jun 08, 2004 7:32 pm
Sure you can't adapt it to fit somewhere else?
Project Thread
Stu-
Postby Monsterbishi » Tue Jun 08, 2004 8:03 pm
Fairly sure, I'm guessing the ECU actually knows what it should be hearing even when in a knock-free situation, I tried just earthing the sensor against the engine block, and the CE light still came up...
--- Cut Here ---
Monsterbishi
Postby ams » Thu Jun 17, 2004 11:05 pm
Have you tried maybe try putting a small resistance (measure resistance of knock sensor) across between the sensor wire and the block (earth)?
This MAY fool the ECU into thinking the sensor is connected (no CE light) and won't cause the engine to retard timing due to false knocking.
Or couldn't you just wire up the sensor but just tape it to a wiring loom or something non metallic? The sensor I think is piezo-electric and will only put out a voltage when it detects a certain frequency at a certain intesity. So if you do this, it shouldn't retard timing.
Just some idea :)
ams
Users browsing this forum: Majestic-12 [Bot] and 69 guests
