ST205 standard boost
Postby TRDmod » Tue Jun 15, 2004 3:40 pm
what is the standard boost for a st205 1996 celica? what psi and bar
i knew it at one stage but forgot
Have you got the hots? for what's in the box with the dots? ..... 0800 30 40 50
Domino's Pizza.....
TRDmod
Postby gt4mike » Tue Jun 15, 2004 9:09 pm
5 bar
gt4mike
Postby Al » Tue Jun 15, 2004 9:11 pm
5 bar is a bit low isnt it? I would have thought at least 6
Al
Postby Scottie » Tue Jun 15, 2004 9:25 pm
on gran turismo it says 6.257 bar
Scottie
Postby Monsterbishi » Tue Jun 15, 2004 10:18 pm
Zomb wrote:on gran turismo it says 6.257 bar
<g> That's 91.97psi, Hmm, would make around 10,000hp...
--- Cut Here ---
'94 JDM Ford Mustang GT Coupe
Monsterbishi
Postby MrOizo » Tue Jun 15, 2004 11:24 pm
or a mess ;)
MrOizo
Toyspeed Legend
ok
Postby TRDmod » Wed Jun 16, 2004 8:43 am
thats real cute people...
but thanks anyway
Domino's Pizza.....
TRDmod
Postby StarbuckST205 » Wed Jun 16, 2004 2:36 pm
my apexi gives .8 bar as the default boost, however i suspect that the stock setting may be somewhere around .5 - .6
hope that helps
StarbuckST205
Postby MrOizo » Wed Jun 16, 2004 3:06 pm
StarbuckST205 wrote:my apexi gives .8 bar as the default boost, however i suspect that the stock setting may be somewhere around .5 - .6
hope that helps
is yours completly stock? like stock air filter (setup) and exhaust?
just curious :)
MrOizo
Toyspeed Legend
Re: ok
Postby Wildcard » Wed Jun 16, 2004 4:23 pm
TRDmod wrote:thats real cute people...
but thanks anyway
Do a search, the question has been answered MANY times before.
Wildcard
Toyspeed Founder
Postby Scottie » Wed Jun 16, 2004 8:56 pm
13psi std boost, when the turbo vsv is closed its 11psi
http://www.st205.net/frameset.htm
under 'technical info' link
Scottie
Postby StarbuckST205 » Fri Jun 18, 2004 2:52 pm
hope that helps
just curious :)
no it has a custom exhaust + air filter
StarbuckST205
